Looking to buy new head unit, back speakers and amp.
Old Feb 10, 2010 | 10:23 AM
  #51
Deadsnake's Avatar
Originally Posted by Dbl_D718
To install what, the amp? You'll need a wiring kit like linked earlier, and depending on what all you're installing, you may need a couple extra things...
Installing the head unit, i got a harness and tried hooking it up last night, power , chimes everything worked but no sound from the stereo came out, i think i am missing a piece...
Old Feb 10, 2010 | 11:53 AM
  #52
alright buddy, if there is one thing i am an expert at its car audio!! i could go on for hours and hours. first things first go with a pioneer head unit any of them thats above $150 and NOT FROM WAL-MART!!! all that walmart bull is knock-off with pioneer name. dont go above 8 gauge wire for a 1000 watt amp, use about 12 gauge for teh speakers make sure they are all the same length. speakers go with kenwood, clarion, SPL,and infinity has some ok speakers. if you are looking for a new amp id go with a power acoustic gothic series, they put out alot of amps with less watts. umm, if got any questions about car audio feel free to PM me.
Old Feb 10, 2010 | 11:54 AM
  #53
Dbl_D718's Avatar
I would doubt you're missing a piece of the kit. What interface did you use? IIRC, the interface will have RCA connections for you to hook up your headunit to for use of the factory amp. If you've done this according to the interface's installatioin instructions, my next guess would be forgetting the remote turn on wire.
Old Feb 10, 2010 | 03:53 PM
  #54
Deadsnake's Avatar
Scosche brand interface, idk it seemed like i did it right... there was a wire that was loose but all the other ones were taken.
Old Feb 10, 2010 | 06:15 PM
  #55
Dbl_D718's Avatar
Sorry man, everything you just said shows pretty clearly that you're no expert. Pioneer is good but not a headunit god, and every Pioneer at Wal-Mart is the exact same as it would be at Best Buy or Crutchfield; they're not knock-offs. Alipine, Eclipse, and lots of others are just as good as Pioneer, and better in some ways. Next, 8 gauge wiring is not big enough for a 1000 watt RMS amp. Also, 12 gauge speaker wire isn't really necessary for most systems; it's fine to use but usually not required. Next up, Power Acoustic is definitely not the brand an expert would recommend for amps, they're usually overrated on output by a long shot.
Old Feb 10, 2010 | 06:40 PM
  #56
Deadsnake's Avatar
soooo what do i do..lol
Old Feb 10, 2010 | 07:03 PM
  #57
Dbl_D718's Avatar
There's not much I can do for you from here. Step one would be go back and re-read all of the instructions and double check your work and connections. Figure out what the one wire you didn't connect to anything is. On your headunit, there's probably a wire that's blue or blue with a white stripe; make sure it's connected to something.
Old Feb 10, 2010 | 09:24 PM
  #58
no dude, dead givaway walmarts pioneers dont have a "function" button. look it up. i know car audio!!!
Old Feb 10, 2010 | 09:28 PM
  #59
not just any power acoustic buddy, gothic series, and i thought you were going max power 1000W. no you dont need 12 awg. but itll sound a hell of alot better. thanks for your opinion though
Old Feb 10, 2010 | 10:04 PM
  #60
Dbl_D718's Avatar
Max power ratings are meaningless numbers used for marketing. RMS power is the only thing you should ever look at.
