6th Gen ('00-'05): keyless entry
Old Feb 4, 2015 | 07:03 PM
owens91's Avatar
Default keyless entry
hey there folks this has been happening for some time and it just crossed my mind to actually ask about it. so when i first got my car around 3 years ago i have keyless entry, it worked from very far away. but now today i have to be pretty much in front of my car to unlock it or anything, i changed the battry and nothing has changed at all. its the normal factory keyless entry system, i thought about getting a whole new factory one but i dont know how to set that up, so what could i do to fix this?
Old Feb 4, 2015 | 09:11 PM
Owen:
Not sure whats going on..
Maybe possibly a dirty/bad body ground...
Or you could try this option..
Old Feb 15, 2015 | 12:14 PM
JohnLovesTrees's Avatar
maybe a bad receiver? for the signal
Old Feb 15, 2015 | 04:28 PM
owens91's Avatar
how does one check for that?
Old Feb 15, 2015 | 11:18 PM
JC Colon's Avatar
I've seen this on many electronics that move or are moved around. With the key fab, you can only drop it so many times before it starts acting stupid. You can go in and try to replace the components but unless you have some soldering experience, it's not an easy job.
The other question is, do you have an Aftermarket alarm? You can have your a/m alarm remote programed to take over the functions of the fab.
It sounds like normal wear and tear to me
Old Feb 16, 2015 | 10:40 AM
maybe use a volt/ohmeter. i think youd neeed to get the wiring diagram though, i have it in my MC book but i dont think the pic would come out good lol. but id try to test the solenoid that actually opens the door or see if the line that is supposed to activate it (solenoid) is actually doing its job.
Old Feb 16, 2015 | 10:14 PM
JC Colon's Avatar
Testing the Solenoid and wiring is easy. Push the button on the door. Lock, Unlock, Lock Unlock! If the door switch works every time then the system works and the problem is in the Remote system. If not, then bust out the Ohm/Multi Meter and have at it! I think Jason may have or know where to get the wiring diagram for it! He does own a Monte Carlo Repair Library! Sorry to put you out there Jason!
blahblahblah
Dec 7, 2008 03:51 PM
brandi_dimick
Nov 15, 2006 06:47 AM
00MC
Jan 27, 2006 09:17 PM
amhoet
Jul 15, 2005 11:55 PM
