Interior Speakers
I was offered Brand new in the box 6x9's but they are from walmart... I took them for no reason and i was wondering what is better these or the factory speakers..
And Also what size speakers go in the Front doors.? Xpress 6 X 9 Car Speakers, Triaxial - Walmart.com |
Ive read a lot of threads on here about car stereos and it seems that most people say that the stock amp dont sound good with aftermarket speakers. You could hook them up and try them out tho.
All things considered, our stock systems arent too bad. What throws things off is the fact on the premium systems they used 2ohm speakers. Since most aftermarket speakers are 4ohms thats where the "problem" comes in. Upgrading the speakers only will result in an upgrade based on the sound but you wont get the same volume due to the increased resistance. Not only that, but you'll still have to deal with the integrated bass inhibit once the volume goes above a certain level. I highly suggest replacing the head unit when you replace the speakers, or an aftermarket amp and bypass the factory one.
Originally Posted by Milhouse
(Post 456714)
Chevy BYPASS AMP Radio Wire Harness Stereo CVY-2021 | eBay Thanks. |
Originally Posted by Bait
(Post 459247)
To bypass factory amp on a 00-01, installing aftermarket and running new wires to speakers, can i just unplug it or do I need the bypass for it. I will also maintain the factory headunit , for now.
If you're keeping the stock headunit, don't bother with aftermarket speakers, they won't sound as good as the stock ones off the stock headunit.
It probably will make it even worse if you go and bypass the stock amp also. |
Originally Posted by trewyn15
(Post 459274)
(Post 459274)
Am I required to use the bypass or can I just unplug it?
(Post 459651)
| All times are GMT -5. The time now is 09:30 AM. |
