Interior lightning question on a 5th gen
Old Oct 1, 2012 | 08:26 AM
natedawg061987's Avatar
Default Interior lightning question on a 5th gen
Hope everyone had a great weekend!
I want to know how hard it is to wire in a panel of LEDs in my dome light. The biggest direct replacement I have found only has 9 LEDs and I fear they won't produce enough light.
Old Oct 1, 2012 | 09:50 AM
It was not that hard. All i did was spin the positive wire around the positive side and spun some of the negative wire around the negative terminal. Then I used electric tape to keep them on. It worked and I think it was a 30 led panel from autozone but any
parts stores should sell them.
Old Oct 1, 2012 | 01:19 PM
zzapultimate's Avatar
It's pretty simple. I did pretty much the same thing as Zach said above ^ It's just a matter of matching positive to positive and negative to negative. Good luck
Old Oct 1, 2012 | 04:29 PM
That sounds easy enough. What did you guys do to keep the panel in place? I know my fixture has the wrap around festoon set up which is why its so difficult to find the replacements with more LEDs.
Old Oct 1, 2012 | 05:30 PM
I held mine up with a small screw through the center of the LED array and into the plastic housing of the dome light structure.
christophe mc france
Mar 17, 2010 04:09 PM
nemesis
Jan 30, 2010 02:36 PM
ludamike81
Sep 17, 2009 07:00 PM
jshep
Dec 7, 2007 08:48 PM
