Installing a Remote Lead in 6th Gen Montes
After searching the forums for awhile and finding several threads that led to "not-so-helpful" results, I thought I'd post what I have found.
**I did this on a 2000 Monte Carlo SS WITHOUT a factory amp. The purpose of this install was to create a remote lead for my mono amplifier in order to run an amp and sub with the factory stereo still installed. ** The ideas for the adapter and fuse came from member Milhouse, I'm hoping this will make it easier for people in the future ** I purchased a fuse tap off of eBay that looks like this: http://i1089.photobucket.com/albums/...1/FuseTap1.jpg After looking through all of the fuses (on both the driver and passenger side) and testing them with a lighted detector, I decided to install the fuse tap and remote lead in the driver's side fuse panel in the 10A CIG/AUX spot because I found that it was dead when the key was off, but was live when the key was in ACC or ON. Here's what the fuse tap looks like installed, I think it looks a lot cleaner than just ramming the wire in: http://i1089.photobucket.com/albums/...11/FuseTap.jpg http://i1089.photobucket.com/albums/...1/FuseTapa.jpg Then I ran the remote lead behind/under/through parts of the dash so as to have it hidden completely. It comes out on the passenger side underneath the glove box so that I can run it along with my power wire for an easier install. Comments/Questions/Suggestions? --Zach |
You could have simply used the remote power lead on the back of the radio. It's there even if you have no amplifier as the antenna module on the rear glass uses it as well
Pin B3 (white) on the 24 Pin Connector behind the radio http://www.bbengineer.com/cars/impal...nteRadioC1.jpg BBEngineer |
Interesting....I just posted this exact pigtail and suggested that exact fuse to use on this install not too long ago when someone asked this exact question.
Originally Posted by Milhouse
(Post 345714)
That wasnt my goal, to get credit in the thread, I was just putting it out there that I had infact given this same info in a previous thread recently since you said you only found not so helpful posts about it after searching. But thanks, I appreciate it ;)
