info- Pioneer AVH-P2300dvd in a 2006 Monte
I was looking into the pioneer 2300 dvd, i was wondering if anyone installed a 2300 or somthing similar in a 06 monte. im need some info, i heard it was a challenge to install due to the parking break. im also not so sure of the factory harness in the 06 montes. any info would help :thumbsup:
Are you talking about the parking brake to get the video to play? You can usually wire that to a ground or a constant power (depends on the unit)
Also you will more than likely need to dremel a small plastic bracket out that will be behind the headunit for all the wiring to fit. |
Ive herd from other pioneer users that the parking break to ground wire trick doesnt work, it has to be done some other way. But I dont know what that is. someone on here should get you up and running though
Originally Posted by jaws2008
(Post 366850)
U gotta run a relay for it to work, hadda do it on my 4200
i heard about the relay also, but not to sure how the stock wiring harness hooks up to the parking break.
That dosnt work tried it, ill get a write up for the relay on here, its pretty easy to do
Originally Posted by LTs_Carlo_SS
(Post 366770)
i have a pioneer avic z130 my self, and its the most powerfull and largest double din from pioneer, with perifials like the HD radio, so if i can squeeze that you'll be fine. far as the bypass, just youtube up 2300 avh video bypass, or 4200 video bypass if they didnt bother remaking a video for the 2300, they are gonna be the same thing. because all of the avh's are designed pretty much the same. |
sweet, im also trying to find a good harness to go along with the new deck. but, theres alot out there. im looking for somthing that will keep most of my chimes, and
steering wheel controls. sucks if those have to go. whats everyones opionion on the PAC C2R-GM29. |
We had this problem grounding it at work - I work at Best Buy. Never did get the video to work for the display if I recall correctly. :/
| All times are GMT -5. The time now is 02:43 AM. |
