I need sub specs
Old Jul 28, 2010 | 04:57 PM
gdixonjr's Avatar
Default I need sub specs
I have two 15" speakers and the box i have them in now is too large to fint in the trunk of my 04 monte. Can someone plz give me the specs on a box that will fit so i can go to homw depot and get it cut. thx The speakers are two Rockford fosgate P1 and i would like the box to be ported. thanks again
Old Jul 28, 2010 | 05:18 PM
eviling's Avatar
Minimum Ported Box Volume 2.66 cubic feet, for the P1S815, whitch is the driver i found based on your descritpion, a p1 15" RF subwoofer, anyways my friend i found this in 10 seconds do the leg work your self. if you need help figuiring out how to make it, that we'd help but your just asking us to do work for you, and that min ported volume is PER woofer. so do the math my friend.
Old Jul 28, 2010 | 05:39 PM
gdixonjr's Avatar
wouldnt have taken less time to tell me the dimensions then go on your little rant?
Old Jul 28, 2010 | 05:51 PM
eviling's Avatar
took me 20 seconds for the rant, 10 for the specs. copy paste my friend, copy paste. good luck with your build. hope to see your build log up on the forums some time.
Old Jul 28, 2010 | 09:28 PM
Nocturnx's Avatar
LOL made my night hahaha
Old Jul 28, 2010 | 09:36 PM
gdixonjr's Avatar
I would love to post it, as soon as i get some measurements. I have been looking but still cant find what i need.
Old Jul 28, 2010 | 09:43 PM
eviling's Avatar
normily...nobody would ever give you the work, but im in a nice moode. so here you are.
you're looking at something thats like 30 wide, 20 deep, 16 tall. that would give you 5.55 Cf, so you'll need to make it a bit smaller than that. 2.66 x2 = 5.32, so with a port that 30x20x16 box would give you just about you want, depending on the subs the hole size is deterimned, i can't do that, as it requires a program, and the exact data. you can try and build some boxes and see what you feel sounds best. usialy something from 22-38 hz, my box is down to 32hz, but mine are completly dif woofers, with much different style cones and responses. plus i'm pusshing well over 1000 watts rms.
Old Jul 28, 2010 | 09:48 PM
ded548's Avatar
Default Enclosure Calculator
Try this!
http://www.bcae1.com/spboxnew2.htm That should help you out. It's hard to help you with exact measurements when we don't know what material or thickness you're using or planning on. Good luck with your build! Should be something of a loud car when you're done.
Old Jul 29, 2010 | 10:39 AM
eviling's Avatar
its AxBxC = x\1728 your 3 lengths being A B and C, but that only gives you the square inches, you device it by 1728 to get square feet, or you can device each number by 12 before you multiply them. same result, but remember to take out the thickness of your walls, thats a square inch or inch and a half all the way around. can really throw your numbers off
Old Jul 29, 2010 | 02:28 PM
gdixonjr's Avatar
thank u. that helps. Ill keep you guys posted on the build
