How do I swap a speedo gauge face?
Ok, so I have a "limited edition" speedo gauge face I got from a guy on craigslist. The problem is I have no idea how to swap it out with the other one. I know how to remove the dash and take the cluster out, im just lost after that :rotfl: . Anyway, how would I go about swapping the face. Im not replacing the whole cluster. I simply just want to be able to take mine out, put new one on and put it back together without breaking anything or screwing anything up.
How would I go about doing this? All feedback is greatly appreciated:thumbsup: |
Before you take the cluster out start the car and let it idle down. Then once it idles down take a pic of the gauge's so you can know the location. I took a pic of my gauges with the car running and one with the key turned to the ACC. Then you can take out the cluster. Once you get it out there are about 4-6 tabs holding the front cover on they just use a flathead or something to press the tabs and slide the front cover off. After you take the cover off you can use a fork to remove the needles. Just slide the fork under the needle and lift up. You might have to slightly rock them side-to-side be careful you dont wanna damage the stepper motor while doing this. I forgot to mention before you remove the needles turn them fully clockwise then counter clockwise till they cant move then take off the needles. Once you get the needles off the gauge overlay just peels off now you can put on your new overlay. Before you put your needles back on plug in the cluster and turn the key to ACC this 0's the gauges while its pluged in and turned on you can put all the needles back on just remember to use the pic you took with the key turned to the ACC. You might have to remove some needles a few times to make sure the are at the right position.
Originally Posted by shotime105
(Post 546763)
Before you take the cluster out start the car and let it idle down. Then once it idles down take a pic of the gauge's so you can know the location. I took a pic of my gauges with the car running and one with the key turned to the ACC. Then you can take out the cluster. Once you get it out there are about 4-6 tabs holding the front cover on they just use a flathead or something to press the tabs and slide the front cover off. After you take the cover off you can use a fork to remove the needles. Just slide the fork under the needle and lift up. You might have to slightly rock them side-to-side be careful you dont wanna damage the stepper motor while doing this. I forgot to mention before you remove the needles turn them fully clockwise then counter clockwise till they cant move then take off the needles. Once you get the needles off the gauge overlay just peels off now So you can put on your new overlay. Before you put your needles back on plug in the cluster and turn the key to ACC this 0's the gauges while its pluged in and turned on you can put all the needles back on just remember to use the pic you took with the key turned to the ACC. You might have to remove some needles a few times to make sure the are at the right position.
Originally Posted by TMoney
(Post 546772)
When you say "front cover", do you mean the glass cover? And the gauge face peels off? When I put the new one in do I need to glue it on? Thanks for the help
(Post 546773)
Yes the glass and the gauge peels off. Your new gauge face should have some type of adhesive on it.
And where are the tabs to remove the glass. Ive heard the glass is glued on not held on by tabs. Are they screws?
(Post 546782)
http://i.ebayimg.com/t/2001-MONTE-CA...2jw~~60_57.JPG |
(Post 546780)
Oh didnt know there are tabs holding the front glass/plastic on. But how would I remove the old one and put the new one in. There is an outline around the speedo and I cant seem to figure out how it would come out.
Here's a pic before you remove part with glass.. https://sphotos-b.xx.fbcdn.net/hphot...26859594_n.jpg After you remove the black part with glass it looks like this. I changed mine to say Supercharged. https://sphotos-a.xx.fbcdn.net/hphot...10936989_n.jpg |
Originally Posted by zjerry
(Post 546791)
I swapped mine for the limited edition one. I used a hair dryer to help loosen the adhesive and peel it off. Between the adhesive on the limited edition one and the adhesive left on my cluster, it sticks with zero problems.
