How can i instal an aftermarket radio without lossing the message warnings?
Old May 2, 2010 | 04:24 PM
speedySS18's Avatar
Question How can i instal an aftermarket radio without lossing the message warnings?
Hello everyone. im am wondering how i can install an after market sterio in my 2000 Monte Carlo SS. because as you all probably know all the message controlls run through the radio, for example like to reset the oil light or the tire pressure. so if you could help me it would be really awesome!! Thank You!!
Old May 2, 2010 | 04:52 PM
captaindamnit's Avatar
do you have one of these guys?
http://www.scosche.com/products/productID/538
Old May 2, 2010 | 08:33 PM
04MonteLS's Avatar
SonicElectronics sells those for less than $60.
But buyer be warned, that damn adapter caused me the headache of all headaches, including causing communication faults that resulted in me intermittently losing my power brakes.
Old May 2, 2010 | 10:31 PM
Dbl_D718's Avatar
Get one of the correct adapters like linked to above and you'll be fine. You can reset both of those lights without the factory radio, as described in your owner's manual. The only thing you lose is the ability to change settings for your keyless entry, like whether or not the lights flash or horn sounds when you lock/unlock the doors.
The forum's search feature is your friend.
Old May 3, 2010 | 10:29 AM
Dyonysis's Avatar
An alternative is to relocate your stock radio into either the Trunk (with commercially available relocation harness) or into the Glove box. For the latter, there are only 5 wires that need to be spliced and routed to the glovebox (ignition power, accessory power, bata bus, and two grounds IIRC).
Old May 3, 2010 | 02:15 PM
04MonteLS's Avatar
That's what i'm doing this time around
Old May 3, 2010 | 06:55 PM
when u do that.. do you have to buy the $100 add on? And how much is it to do that?
Old May 4, 2010 | 01:28 AM
Dyonysis's Avatar
You don't need the radio replacement module to relocate your radio to the glove box. Just some wire and connectors/solder. Either way, you will need to buy a module to allow the steering wheel controls to work with your aftermarket deck if you want that. I think they run about $100.
Last edited by Dyonysis; May 4, 2010 at 03:14 PM. Reason: Pic was really big, should correct to a reasonable size itself once the server refreshes
Old May 4, 2010 | 02:14 AM
04MonteLS's Avatar
I went ahead and bought the relocation harness, got it for a damn good price! Plug and play is my friend!!! I had been thinking about where i'm going to relocate it to and the center console armrest was my preferred location but that's a no go.....Didn't think it would fit the glove box so didn't even consider it..did you have to do some cutting of the glove box to get it to fit in there?
Old May 4, 2010 | 03:15 PM
Dyonysis's Avatar
It will fit in the glove box like a..... glove. You might have to cut a whole in the back for the wiring.
