How to bypass 2004 monte carlo factory amp
Old Jan 17, 2011 | 06:35 PM
rmase182ls's Avatar
Also how many feet of wire do i need? and what gauge should i use?i do plan on adding amp and subs in future
Old Jan 17, 2011 | 10:08 PM
walkingonabullet's Avatar
16 is fine, i run 14 my self though. 16 on my tweets. you just have to figuire out how to get it through, the passenger side is easy.
a trick is you can pop one end of that gasket off rather easy that way you can grab the wire and push it through the hole on the door, but on the driver side theirs that darned foot break makes it a BITCCCCCCCCCCCH to get that wire in, my first time i got it on the first rtry *lucky* but i know it can be a real pain in the ***.
Old Jan 18, 2011 | 12:36 PM
Milhouse's Avatar
Originally Posted by rmase182ls
Ya i thought about running new speakers wires. But how the hell do i get those wires into the door? i would have to absolutely tear apart my dash right?
Pretty easy. When u open the door you'll see an accordian looking boot, run the wires right through that boot. Check SQMontes sticky thread, he has pics of it in there.
As for wire guage, I honestly dont see the point in tripling the wire guage of whats coming out of the stereo cause ur still just gonna get what the stereo speaker wire can supply. But if u have money to burn, knock urself out. So clearly 16ga is overkill, 20-24ga will be plenty for deck power and it will save u from wasting money on overpriced wire that wont provide any audible difference. just buy a spool of it, 30ft should be plenty.
Old Jan 18, 2011 | 08:22 PM
rmase182ls's Avatar
Thanks guys. Im gunna run all new speaker wires saturday morning. I will make sure to let everyone know. But DBS MC could you post some of those pics you were talking about? i couldent seem to find SQ monte
Old Jan 18, 2011 | 08:44 PM
rmase182ls's Avatar
Never mind i found those pics. I think i know how to get those wires into the door now
Old Jan 19, 2011 | 05:13 PM
02LS's Avatar
yeah. the only time you would run 14-16 awg wire to replace the wires that currently run through the accordion boot, would be when you are running speaker leads from an aftermarket amp.
just get the 20-24 awg wire spool and go to town imo.
unless you are planning on adding an amp later, in which case, go ahead and run the larger wire, you can splice it later inside the vehicle to run to an amp.
Old Jan 19, 2011 | 10:30 PM
Milhouse's Avatar
This man here speaks the truth!
Welcome to the board man
Old Jan 20, 2011 | 02:24 PM
jasonb's Avatar
Hi there,
I am haveing trouble getting the xk01 bypass to save the program. I have installed prostart 3400tw with xk01 bypass. NO CRANK... I have 2004 monte carlo ss sc, any ideas
thanks jasonb
Old Jan 20, 2011 | 02:27 PM
jasonb's Avatar
Hi there, I have 2004 monte, and the factory amp stopped working. can i install an aftermarket amp in its place
thank jasonb
Old Jan 20, 2011 | 02:37 PM
thank jasonb
youd need a converter like a rocker fosgkate 3 sixty, or something of the sort, i'd recommend if your happy with your sound just finding sombody with a stock amp laying around.
oh will you look at that, i have a stock amp laying around PM me if your interested in it, or you can feel free ot hit up the dealer but the dealer wants something like 600$ for it, i can probobly do better :P
