Highbeam out message
Old Mar 23, 2014 | 01:32 AM
Steven21's Avatar
Default Highbeam out message
I just picked up a 2003 monte carlo a few weeks back and i keep getting a message for highbeam out. I checked the bulbs and they all work. The weird thing is that it only happens when the drl's are on, if i manually turn the headlights on the message wont appear. Any ideas what it could be, possibly a fault in the drl. Thanks!
Old Mar 23, 2014 | 05:31 AM
I didn't even realize that our cars had a light out indicator. Then it occurred to me that in the 7 years I've owned this car, I've never had to change a single bulb. Weird.
I do know ours cars use the high beam bulb for the DRL and it switches to the low beam when the lights come on. I think it also kills the High beam/DRL when you put it in park, doesn't it? Are you sure your checking the right bulb?
Old Mar 23, 2014 | 08:33 AM
owens91's Avatar
it could be something esle but when this happened to me both the highbeams and low beams was on at the same time. what i had to do is change the multifucntion switch on the steering coloum. make sure you check the fuses first and the relays as well
Steven21
Jun 29, 2017 11:51 PM
owens91
24
Dec 27, 2013 02:09 PM
Jason Roush
May 29, 2012 08:31 AM
Magna131
Oct 27, 2005 04:36 AM
