HELP: Brake light problem
Old Jan 19, 2010 | 12:54 AM
gothkid's Avatar
Default HELP: Brake light problem
Ok so i got pulled over today for no tail lights, and naturally i was like what the heck. So i got home had a friend of mine step in the brake. They work so i was confused, drove to the police station to show the cop they worked. When i press on the brake they didnt work, he step on the break aswell so i could see. I ended up driving back home and had my friend step on the brake again and they worked. We drove down the road to the stop sign and they worked, drove down the road they stopped working. Then we drove back home and they worked.
Help me whats goin on here?
Old Jan 19, 2010 | 08:49 AM
Good chance your multifunction switch is having issues. Your brakes are actually run through that also
Old Jan 19, 2010 | 11:52 AM
JaxJim's Avatar
I'm sure there's a switch on the brake pedal as well that's probably the cheapest and easiest swich to look at first.
Old Jan 20, 2010 | 07:59 AM
gothkid's Avatar
well i just replaced the brake lights and so far it has seemed to fix it
Old Jan 20, 2010 | 05:31 PM
I remember ryan(skylark65) having brake light issues earlier this summer, I forgot what it was, maybe he'll stop by soon and let you know!!!
Old Jan 20, 2010 | 06:17 PM
Dbl_D718's Avatar
I had this problem with my old 95 Cutlass and it was the turn signal switch. Have your friend hit the brakes and then turn on the turn signal, chances are the oposite brake light will go off. Hold the turn signal lever in the right spot and you might find a position that makes your lights work lol.
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
rgant_19
May 8, 2010 11:47 AM
