Heads Up Display
Old Jun 9, 2011 | 07:05 PM
Jester_20's Avatar
Default Heads Up Display
Some may think it's pretty cheesy, but ever since i seen it in my buddies GTP I've thought it was pretty cool. I haven't heard of anyone putting a heads up display in a car that didn't have one stock, and really didn't think it was even possible, yet after looking on ebay, i've found one that sounds like it's plug and play. (link below) Has anyone ever installed anything like this, or even know if it's possible on our cars? (i know it looks pretty cheap, but it's a good example)
Heads Up Display HUD KM OBD Rpm/Speed/water temp/volt | eBay
Old Jun 11, 2011 | 10:34 AM
SpinEm_90's Avatar
I've been wanting to put one on my monte for a while now but i hear that you should get a special type of windshield put in the car so the display is clear soo idk
Old Jun 11, 2011 | 12:54 PM
I'm sure they didn't put a "special" windshield in my 2000 GTP to get the HUD to show up. You can't use polarized sunglasses though - then you won't be able to see anything.
Old Jun 11, 2011 | 02:13 PM
bbengineer's Avatar
Actually.. they did... there are 2 different windshields for the GTP, one with HUD and one without
Typically, there is a reflective area on a HUD windshield that helps make the display more visible
BBEngineer
Old Jun 11, 2011 | 02:24 PM
KJRich's Avatar
The two different windshields must not have been that noticeable to the naked eye, then. I've never seen one with HUD.
Old Jun 11, 2011 | 03:42 PM
Enzo354's Avatar
STILL SLOW
Well it isnt visible, it just reflects more.
Old Jun 11, 2011 | 07:25 PM
BBEngineer
I stand corrected and I do find it very interesting. I don't know why GM would have gone to the trouble....
Old Jun 12, 2011 | 02:09 PM
SpinEm_90's Avatar
Well the corvettes have that kind of windshield. After I test drove a 2007 back when I lived in Pensacola I've wanted one but then i heard that I'd have to change out the windshield & to me it isn't worth that much trouble. I don't want it that bad lol
Old Jun 12, 2011 | 08:08 PM
Jester_20's Avatar
Just a feature that i've always thought was awesome. . . . brock said he's got an app that works like a hud, you just set your phone on your dash . . . . . kinda takes the sweetness factor out of it
Old Jun 12, 2011 | 09:56 PM
I will be doing it on my monte once the interior comes apart again. I've got a HUD, DIC, and BCM from a GP and I took the interior wiring harness and cut it down to the bare minimum wires to work- they just need to be tapped into the appropriate spots.
The hard part about making it work isn't really the wiring- its mounting the thing. If you look on the GP's- when you take that bubble dash off, it sits pretty deep in there. With the windshield in place, you'd have a hard time cutting the dash away, and making a proper mount (unless you pulled the whole dash out of the car which would suck too).
Don't see why it wouldn't work- it looks like it reads the obd info just like any other scan tool would- only it puts the info on a display. Only odd thing is it mentions kilometers and hour 3 times, but never MPH- I'd hope there is some button to switch?
As mentioned above- there are different windshields for HUD and non-HUD cars, although you can't really tell the difference just looking at them.
However, there have been plenty of GP people put HUDs in there cars on the non-HUD windshield (and how many owners have had cracked windshields replaced with non-HUD windshields by companies that didn't care)- and it does still display.
If nothing else, you could always use some film on the windshield like they do in that ebay unit.
It is great to have, and sad that more cars don't come with them.
