headlights shutting off
Old Oct 15, 2006 | 02:27 AM
Nathan79's Avatar
Default headlights shutting off
Hi-
I have a 2003 Carlo and there have been two times that when i was driving home I had my brights on and all of a sudden all the headlights completely shut off. Does anybody know what causes this or has anybody had this happen to them. It took me a little bit to find a way to turn them back on. The first time it happened I was on the interstate heading home when they shut off so I pulled off the road and turned off the car and turned it back on and that didn't help anything. Even the automatic lights didn't come on when I started the car. I finally decided to turn the brights on and they fianlly came back on. Does anybody have any idea what could be causing this? Thank you!
Old Nov 19, 2006 | 04:42 AM
84Monte's Avatar
Default RE: headlights shutting off
The only thing I could think of checking would ne the fuses and fuse box
Old Nov 19, 2006 | 11:54 AM
bbengineer's Avatar
I highly doubt it's fuses... when a fuse blows, it's not intermittent, it's blown...
From the sound of it, you Multifunction Switch is on the way out (that's the stalk that controls the turn signals and brights)... it's a pretty common problem...
BBEngineer
Old Nov 23, 2006 | 01:56 AM
Yellow_Monte's Avatar
Yep I've had a very similiar problem.
Ever since I bought my monte, the brights have always been weird. Sometimes they won't come on when I pull the handle. They usually will get stuck on when I try to turn them off too. On 2 occasions I have been driving with my brights on, and all of a sudden they turn off. When this happens I just switch back to regular lights and then when I go back to brights they work. I'm pretty sure my problem is with the turn signal/bright switch in the steering column.
Yours is a little different because its your regular lights as well. But I would still look into the bright switch as it could be affecting the regular lights. Be aware its a really expensive part to fix though.
Old Dec 4, 2006 | 11:06 PM
RocknSS04's Avatar
My '01 had lighting problems. Flickering and wierd stuff. Had to replace the BCM (body control module) at about 90,000 mi. I'm thinking it's under the drivers seat, under the carpet. The lighting system is totally computer controlled, i'm told. The switches tell the computer what to do, on, off, etc. It's what it took to fix mine.
Helmittt
Aug 1, 2013 08:24 AM
mrbigs
Feb 3, 2013 11:42 AM
mrbigs
Dec 26, 2012 11:09 PM
benh911f
Jun 19, 2011 03:26 PM
llooney18
Dec 29, 2010 01:26 PM
