Headlights
Had an issue with my lights awhile back, replaced the flasher switch and woo la... fixed. All of a sudden I lose my low beams, everything else works just no low beams, I'm having to drive with my brights on, any ideas?
Are the high beams on? I know on the 00-05 the multifunction switch can often fail and prevent switching between the two settings. And to change the hazard module on those, you have to remove the dash, good chance the multifunction switch was bumped. Years ago I had to take my dash apart, I knew my multifunction switch was bad (if you switched to high beams, it was a pain getting it to switch to low beams, since I hardly use high beams, I just left it on low). Well, while taking the dash apart AND putting it back together, I locked it into high. I finally had to replace the switch.
6th Gen ('00-'05): Headlights work when they want to.
Myshell Ray
Mar 22, 2017 12:51 PM
ronniemarlo
Jul 2, 2014 08:44 AM
6th Gen ('00-'05): I have no headlights (only high beams)
Dave McFly
Jan 21, 2013 10:27 AM
