Headlight
Old Feb 19, 2014 | 12:17 PM
lucasmblanco's Avatar
Default Headlight
So I just noticed the plastic covering the lightbulb came off(seen in bottom right corner), any way to get it back into place?
Old Feb 19, 2014 | 12:24 PM
Also, I just got my hid's! They are supposed to be 6k, but as you see they look more like 8k
Old Feb 20, 2014 | 07:30 AM
I am not sure but I think you would have to completely take it off then put it back on. That would probably be the best way is you would know that you get it perfectly sealed so no water or anything gets in it. I know there is videos on YouTube that explain better on how to do it or one of the other forum members can explain it.
Old Feb 20, 2014 | 09:15 AM
dbaldwin's Avatar
Their is no official standard when it comes to Kelvin colors. Most kits will say 6000k is white anything above is more blue anything below is more yellow. But other will say 3000k or 4000k is white. So its hit or miss what color you get. My 6000k have a hint of green in them.
Old Feb 20, 2014 | 09:18 AM
I don't mind the blue too much... But was really looking for white, the guy said they were would be white as well... But it is what it is
Do you have any idea on how to remove that plastic piece?
Old Feb 20, 2014 | 09:26 AM
dbaldwin's Avatar
You want to put it back in to place if possible. It is designed to stop you from blinding other drivers. The best bet is to gently heat the lens up till you can remove the lens. Then re-assemble it. If you have a litte bit of mod money laying around I would buy a set of projector headlights instead. They look cleaner and are safer. Your lenses look pretty pitted anyways.
Old Feb 20, 2014 | 09:28 AM
I did the headlight lense removal and reinstall. Kind of a pain, but essentially it involved using an oven and clamps. There is a thread on here for that for sure. Interesting to know the amber piece actually separates from the lense body.
I only have about 250$ set aside for mods right now..
And if I get projector headlights wouldn't that mean I just wasted 75$ on my hid's for nothing?
Old Feb 20, 2014 | 09:30 AM
Sounds like a tough job zippy... I don't really have much patience for that kind of stuff
Old Feb 20, 2014 | 09:38 AM
dbaldwin's Avatar
Im pretty sure you still need ballasts power to HID's in projectors. I haven't put projectors on a monte yet but im pretty sure you still need all the HID kit stuff.
