Having Trouble Getting New Gauges Hooked!
Old Dec 5, 2012 | 01:24 AM
S.O.G.'s Avatar
Question Having Trouble Getting New Gauges Hooked!
So I just got my triple pillar gauge pod for my 04 monte ss s/c and I'm having issues with it. May sound a bit dumb but am I suppose to remove my factor piece out and replace it with the new pillar gauge or does it simply sit over the piece already there? anything I need to drill, screw on or off? Also, I have the aerofoce interceptor gauge from zzp. How do I go about installing that? where does it connect to? any step by step directions anywhere? I'm not really good with wiring stuff up lol any and all advice helps! thanks in advance!
Old Dec 5, 2012 | 11:30 AM
Monteboy03's Avatar
Hello. The triple pod if it's like mine screws into the original one. I prefer drilling as little as I need to but yours is probably like mine. does yours have tabs on the inside?
ZZPerformance is usually good with giving directions. Did none come with your gauge? Call or email them and they'll send ya some.
Old Dec 5, 2012 | 12:19 PM
01 Monte SS's Avatar
The Aeroforce should plug directly into your OBDII port. No additional wiring should be needed, it gets power and all info. directly from the OBDII. Mine came with about 9 feet of cable which is plenty to run it up to a pillar.
My pillar pod also had two holes for mounting, as it was meant to be installed over the stock pillar, I didn't want to drill into my stock pillar so I just used some 3M double sided tape on the back side. Never had an issue with it, and it saved me from drilling any holes in the oem pillar which would have looked terrible now that I don't have the pillar pod lol.
Old Dec 5, 2012 | 02:49 PM
S.O.G.'s Avatar
idk if we have the same one or not I got mine from ebay for 55. it was the only one I could find! lol but thanks alot!
howd u run ur wires for ur gauges with the pillar pod over the stock one? any advice or cautions while doing this? I think im gonna avoid drilling as well lol
MidNight Rider
29
Jul 14, 2014 08:48 PM
dnls1123
Dec 16, 2010 02:32 PM
Jcb
May 11, 2010 12:37 PM
jay26
Mar 16, 2008 04:08 AM
monteriderLS
Aug 9, 2007 11:22 PM
