6th Gen ('00-'05): Fabricating a trunk lid mat
Old Apr 19, 2014 | 05:33 PM
Well here are a few more shots for the project. The panels come with square edges. In order to better wrap the fabric we will need to round the edges as shown with a sand paper. Be gentle when sanding as it shapes very easily. Used a Loctite fabric multi-purpose spray adhesive from Walmart's fabric section. It's repositionable and dries permanent.
Have the red crushed velvet field applied and the smaller bowtie wrapped. pre-cut the velvet to almost the proper size. Test fit it and then applied according to the adhesive instructions.
I sprayed the larger bowtie black for demo purposes, it will actually be wrapped in a black auto grade vinyl. I'm off setting the bowtie's from the center and am having a Team Monte Carlo with Taz about 6" tall and 12" long embroidered on the black vinyl and will mount it directly below the bowties. Also having 2 fluttering checkered flags 6" x 8" embroidered that will be mounted to each side of the bowties at an angle to simulate them having crossed staffs. And that should be about it, Thinking of using a checked flag material to wrap the 1" thick edge of the field panel to provide some contrast to the actual red trunk lid and the red panel field, but not commited on that detail yet.
Sanding the edges to a radius with 80 grit and then 220 grit.
Finished edges with the 220 grit and a gentle touch.
Note I did the front and back with radius edges, being better able to wrap the fabric
Bowties finished with sanding
Field panel wrapped with the crushed red velvet
Panel fabric bonded to back with spray adhesive.
Want to do a dimensional set of bowties for effect. The lower is just a mock up painted, waiting for the black vinyl to be returbed from the embroidery shop and will then wrap the larger bowtie with it for contrast.
Old Apr 21, 2014 | 05:36 AM
It's looking good so far.
Old Apr 21, 2014 | 08:41 AM
Dubstepticon's Avatar
Very sharp, I really want to try this.
Old Apr 21, 2014 | 02:31 PM
Crusader SS's Avatar
With the theme of your car, I think it would look awesome...
Old Apr 22, 2014 | 01:58 PM
Monroe's Avatar
Monte of the Month -- December 2013
Looking sharp, Greg!
Old May 15, 2014 | 07:36 PM
Bellyisis's Avatar
Hello Greg.
I sent a P.m to you with a request. I'm not sure it went through. Been trying to make my mat for over a yr. Even with help from LTmonte5,4 attempts it still don't fit properly.
Thank you
nemesis
May 31, 2010 11:28 PM
7801MonteMan
Apr 18, 2010 09:05 PM
03Monte
Oct 10, 2009 07:11 PM
nemesis
Sep 14, 2009 02:05 AM
Teacher
Aug 26, 2009 07:11 AM
