Driver Side Window
Old Apr 8, 2017 | 03:01 AM
K11ngVi5chu5's Avatar
Angry Driver Side Window
So, I have my 1998 Monte Carlo, and when I am trying to roll down the Drivers Side Window, it will roll down sometimes,
but then there are times where it will not roll down, or back up, and it will just stop, and I will have to let it sit for a second, where ever it is, and then try and roll it up, and then back down, and sometimes it will catch the little black part at the bottom, and stop, and when I pull it away it will still be stuck, and then I have to let it sit still, and it will sometimes drop a little while it is coming down, and I just want to know if any one else has had this problem, and how did you fix it??
Thanxx in Advance
Old Apr 8, 2017 | 08:28 AM
Smile
Sometimes it is as simple as a new switch you may need to replace the drivers side and the passenger side. Then again it can be the window regulator. Check this link to Youtube and maybe something there in a video will be the thing you need to make the repair. Most of them are all the same inside. Hope this helps.
https://www.youtube.com/results?sear...vy+monte+carlo+
Old Apr 8, 2017 | 10:12 AM
Thanxx, I am going to look over it now.
