-   Interior/Audio/Visual Electronics (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/)
-   -   Can i swap factory deck (https://montecarloforum.com/forum/interior-audio-visual-electronics-11/can-i-swap-factory-deck-33308/)
perryp Jan 10, 2012 06:57 PM
i have a 2000 monte SS stock stereo and i want to change my deck but im worried about losing all the warnings etc like tire monitor reset oil change reset etc is it possible to change decks and keep all these options
Boxman420 Jan 10, 2012 07:06 PM
you will still have those. there are different ways to reset them with out the radio. i have done it a few times already!
KJRich Jan 10, 2012 07:09 PM
You can still reset the oil life monitor through depressing the accelerator pedal 3 times and reset the tire pressure monitor by turning your light switch on and off 3 times (the more specific, detailed instructions are on the site somewhere and in the owner's manuals), but you won't be able to change the other settings accessible through your factory headunit.
perryp Jan 10, 2012 07:58 PM
perfect thanks alot
KJRich Jan 10, 2012 08:44 PM
You're very welcome!
lougreen03 Jan 10, 2012 10:16 PM
Some people buy an additional harness for the factory stereo and either mount it in the trunk or just run the harness into the glove box and just hang onto the radio. Then just pull it out and hook it up when you need it.
