Blown speakers?
Old Apr 27, 2006 | 12:03 AM
enigmatic23's Avatar
Default Blown speakers?
I installed my amp but now the right speakers on the front and the back doesn't produce sound unless the radio is turned all the way up and then theres static. Do you think I blew the speakers? I thought that could be it but i've never blown two speakers together before especially like that
Old Apr 27, 2006 | 01:14 AM
04MonteLS's Avatar
Default RE: Blown speakers?
I find it highly unlikely that you blew only the right side speakers. To test this theory, connect the right side speaker to the left channel on the amp and see if the result is the same, if it is, it's a speaker problem. If it's not, the problem is in the amp. Check your gains and crossover settings, set the right side as the left side is set(if you even have control for left and right). Make sure your rca's are connected properly and basically double check all wiring. Get back to me with your findings.
Old Apr 27, 2006 | 01:49 AM
I thought of that as soon as i posted the question so I went and did that. The right side isn't blown but there is still no sound just static when i turn the volume all the way up. So the amp can cause the right side blow completely? Is there a fuse for that or do I need to get a new amp? Thanks for your help by the way
Old Apr 27, 2006 | 01:55 AM
04MonteLS's Avatar
ORIGINAL: enigmatic23
You thought of what and did what? I love car audio and love helping people with it whenever possible. Connect one of the right side speakers to the left channel on the amp and tell me what happens, if it plays fine, it's an amp problem, if it doesn't play then it's indeed a speaker problem.
Old Apr 27, 2006 | 02:11 AM
It's an amp problem. I connected the right side to the left side and it played fine. I guess i'll have to find a new amp
Old Apr 27, 2006 | 03:32 AM
04MonteLS's Avatar
Just for the hell of it, switch the rca's and see if that alleviates the problem. But if you need an amp, I've got a Soundstream Reference 414S for sale
Old Apr 27, 2006 | 04:41 PM
I called cartoys and they said I couldn't bypass it with my factory radio and the only other way is to get an aftermarket radio. So is there a way to bypass it without changing my factory radio?
Old Apr 27, 2006 | 07:54 PM
03SSdriver's Avatar
Along the same lines.. whats the best ( or recommended) 2 ohm speakers for the mc?.
Infinity?
Memphis?.
Tj
Old Apr 27, 2006 | 07:55 PM
04MonteLS's Avatar
I called around and asked about the factory amp's price. They said it would be over $700 and i'm not paying that. I called cartoys and they said I couldn't bypass it with my factory radio and the only other way is to get an aftermarket radio. So is there a way to bypass it without changing my factory radio?
Yes, you can bypass the factory amp while keeping your factory head unit. Do a google search for Impala amp bypass and you'll find all the info you need.
Old Apr 27, 2006 | 07:59 PM
04MonteLS's Avatar
ORIGINAL: 03SSdriver
Infinity?
Memphis?.
Tj
Best is a subjective term, although I'd lean towards the Infinity over most others out there. If I didn't already have a competent setup with my Polk Audio mids/highs, I'd definitely pick up some Infinity's. And good luck finding 2ohm mids/highs while being able to keep all your limbs
