Best sub placement
Old May 22, 2010 | 11:46 PM
JOETHEPRO's Avatar
Default Best sub placement
should the subs hit better seated forward toward the back seat or backwards toward the rear end of the car. (in the trunk of course)
Old May 22, 2010 | 11:49 PM
lucian*91's Avatar
ohhh lala. nice car! but anyways to the topic. i dont know the answer but i leave one part of the back seat down on mine to get a nice effect
Old May 23, 2010 | 12:10 AM
Justin's Avatar
ive always found that the subs will sound louder if they are facing the trunk, but then again i matters on what type of encloser your subs are in as well.
Old May 23, 2010 | 03:04 AM
JOETHEPRO's Avatar
yeah i had them towards the trunk and it sounded good with a bandpass box but once i switched the box and subs to regular enclosure i turned it around. It sounds good but not like it used to. And i do the one seat down trick to to make it louder. IT WORKS!! haha i need a new amp though my amp is underpowering my subs. 800w subs (2) and a 350w amp.
Old May 23, 2010 | 03:17 AM
GreenEyedMonte's Avatar
Face the subs toward the rear, this gives the sound waves room to expand..
Old May 23, 2010 | 06:31 PM
BUDDZZ's Avatar
If you put them facing the seats you will get a much clearer punch, where as facing the trunk will amplify the lower bass tones.
Old May 23, 2010 | 06:43 PM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Put them facing out the back of the car... sounds better every time!
Old May 23, 2010 | 06:45 PM
Yeah, always should be towards the back except when you have a bandpass, then that should be facing upwards (usually) there are exceptions to all the different ways to positions. And then agian, alot of it has to do with your sound preferance.
Im sure 04monteLS will jump in somtime and give you his know-how>> He'll clear this up real good.
Old May 23, 2010 | 08:03 PM
mak330's Avatar
you'll get bigger lower bass if you face them towards the deck lid.
a lot of members face them towards the back seat if they have enclosers that showoff the subs. then they will cut a hole wear the rear armrest is. this allows them to easily get sound or hide it away when neccisary.
you almost have to cut a hole or leave a seat down when you face them forward. all the bass will reflect off the seat and stay in the trunk.
Old May 23, 2010 | 08:31 PM
04MonteLS's Avatar
If you have a ported box, it usually sounds better firing towards the back. If you have a sealed box, firing forward is usually best. But, you can have a ported box firing towards the front too and it'll sound lovely if you go through the pain of sealing off the baffle from the rest of the trunk, including sealing off the rear deck. If you don't seal it off like that it'll suffer horribly from cancellation.
But like always, the end all be all should be how it sounds to you. Try your box in different positions until you find the one that suits you the best.
