Id run it just like u would for an amp power wire, threw the firewall & under the carpet on one side, under the rear seat & into the trunk & ground it somewhere in the trunk, my 300c has the ground in the trunk, if u ever plan on shaving the key hole on the trunk than ull deff want a jump point under the hood if ur battery goes dead
I didn't know the challengers had them in the trunk. The 06 Bonneville had them under the rear seat. We went to jump my buddies car one night after work and couldnt find the battery:rotfl: He just bought the car and had no idea where it was.:eek:
I run a battery to back of my monte. I just used 4 gauge wire to run to my back battery and it is plenty big enough.
(Post 494214)
Alot of newer vehicles are goin to the back & all ive seen have jump spots under the hood
Originally Posted by DE02Carlo
(Post 494191)
People used to move them to the trunk for weight distribution. It also keeps the battery away from the engine heat. The new Dodge Challengers have them in the trunk.
You have to make sure you have the right gauge cables to go that distance..
(Post 494201)
Ive thought of doing that before, it'll definitly clean up the engine bay some. Best place I could think was the spare tire area and running the wires underneath the car, then just run them through the drain plugs that are in the trunk ;) Lol
Ive also thought of relocating my coolant reservoir tank but I'm just leaving everything where it is.... No need for my engine bay to look all clean and pretty, I'm the only one that sees it most of the time anyways lol and I drive the car everyday... My motor already had a bunch of debris all over it after 2-3 days of driving it :rotfl::nono: But yours is looking Pretty badass now :thumbsup:
(Post 494203)
(Post 494214)
(Post 494220)
(Post 494223)
The new Camaros have them in the trunk too. Luckily they have terminals for jumping located in the engine bay though :rotfl:
If you are going to store it for the winter and are tucking the battery away, try to think of a way to make a spot for the tender wires to go so you don't have to leave your trunk open :P
Unless you just remove the battery for the tender. |
Where the good/best place to run a ground? Also will a 0/1 guage fit through the interior or should i run it underneath the car and crimp it to the body?
(Post 494236)
Unless you just remove the battery for the tender. Here are some renderings I just did of what is going to be replacing my battery. Not at all precise, didn't even measure anything, just went by memory/guessing. Once I get home later today I'll get real measurements and see what I can come up with. I plan to relocate the fuse panel to where the opening in this box is. There will be plexiglass/leaxn covering it, possibly some red leds in there to light it up all fancy at night :thumbsup: I'm thinking I'll make the top part on some sort of hinge so it isn't a pain to change a fuse. Made with Solidworks and PhotoView in about an hour (probably should have paid attention in class but this was more fun :)) and no this isn't my highest quality of work. Black? http://i1205.photobucket.com/albums/...iewFusebox.jpg Or chrome/polished? http://i1205.photobucket.com/albums/...viewchrome.jpg The round cut out on top is for the washer fluid tube, rectangle to make the fuse box visible, two small posts will be where I put some custom battery terminals In case you can't visuallize this, it will be going directly behind the frame area behind the passengers headlight. Should span from the frame to the fender. Attempted to make it round to fit the fender on the upper end and angled to fit the frame. Not exact of course. |
(Post 494180)
My K&N intake will actually be coming up for sale here soon. Making something custom and more awesome, going to keep it a surprise til I'm done though :) |
| All times are GMT -5. The time now is 05:12 AM. |
