background noise
Old Dec 7, 2010 | 03:22 PM
ctownbandit's Avatar
Default background noise
i have a background noise in my speakers how do i stop it
Old Dec 7, 2010 | 04:22 PM
what do you mean by background noise?
Old Dec 7, 2010 | 07:03 PM
eviling's Avatar
lets troubleshoot. first.
when did the problem start?
what have you changed since you had it working properly?
what have you tried?
describe the results to what you tried.
and a list of all equitment you have installed along with year of car. than we might be able to help you
Old Dec 7, 2010 | 07:25 PM
theres a squeal comming from the speakers
Old Dec 7, 2010 | 07:27 PM
I just bough the car and it was hooked up to have an amp push the interior speakers, so i hooked up the amp and now everything works just a sqeul comming from them. I read that it could be the power wires are to close to the speaker wires, i have no idea i plan on rerunning all the previous set up to where i like just that this squel is annoying for now
Old Dec 7, 2010 | 08:15 PM
it could be a bad ground.
i would check the ground, mine did the same thing and as i accelerated it got louder, but i moved the rcas away from the power wires and it was fixed.
Old Dec 7, 2010 | 08:59 PM
eviling's Avatar
im out. i dont tolerate laziness. you want something fixed you do the leg work. not me.
Old Dec 7, 2010 | 09:10 PM
what??
Old Dec 7, 2010 | 09:47 PM
jaws2008's Avatar
GOT SPL
what??
x2 lol
Did you do anything with the head unit. its very easy to get wires touching back there that can cause noise in the system. Usually noise is caused by bad ground or RCAs coming to close to power wire.
Old Dec 7, 2010 | 10:27 PM
eviling's Avatar
guy comes in here say8ing 2 lines no list of gear, no list of things hes tried before bugging us with his troubles or even so much as a name. worthless as far as im concearned, do your own scut work.
