One other thing-for you guys that have taken out the center console-how big a pain is it? Wanted to light up the cupholders and the center console storage and like to know what I'm getting into.
Not a big deal. You have to be able to see a little bit with your hands and be carful not to break anything. Turn the key the acc and set the E brake. Put the shift lever into 1 slide down the vinyl cover and use a flat head screw driver to pull out the U clip (like a big staple) and remove the shift handle. Then remove the screw in the tray under radio. Then pull it up from the back and it should come right out. Just know that its tight in their you might have to relocate some wires. (If you have heated seats. Otherwise it should be easy) I just tucked mine underneath the shift assembly instead of on top.
Also on a side not I'm changing my switches to blue and intalling some trunk lighting soon.
A switch. I have a ricey street glow switch box I got back in highschool. It's honestly really nice.
Ahhh. All my stuff is wired to the power for my interior lights (cause they are all blacklights and easy to drive with) also have my red led switches that arnt hooked up to anything yet.
