Altinators anything bigger?
Old Dec 3, 2006 | 10:23 AM
mickey's Avatar
Photobucket
Default Altinators anything bigger?
hey all i noticed the other day i think the alt is bad on the monte. if i leave it sitting to long in a parking lot with the radio going it is not wanting to start. This is with a yellow top in it that is less then a year old. So im thinking the Alt might be going on it.
So i started checking around for a new one. (thank god i was sitting down for the price on them)
But do they make one that is bigger then the 105amp?
I have a decent system in it that is also not helpign things out so i figure if i can solve a issue with the Alt being over worked i would also do it.
but man 160.00 for a alt with a 45.00 core OUCH!!
shame i cant find the rebuild kits for them i would do it my self LOL
Any help would be great on this.
Thanks
Old Dec 3, 2006 | 04:53 PM
04 Intimidator's Avatar
Default RE: Altinators anything bigger?
This might help with powering your stereo: Alternator rewire kit
Here's a 105 amp alternator on Ebay for $25 from an 02 on a 3800.
Ebay alternator
Good Luck
Old Dec 3, 2006 | 08:47 PM
mickey's Avatar
Photobucket
thax i have it being watched so i can find it again.
goining tomarrow to have it checked out also to have the bat. load tesyed to make sure it is not that to
Old Dec 3, 2006 | 10:14 PM
DESS03's Avatar
heres a place that sells alt for our car at 200 amps
ho alt specs
Old Dec 3, 2006 | 10:31 PM
J_Bru_Ha_SS's Avatar
Yeah I just did a search and came up with the same site that DESS03 did. There are plenty of sites out there that offer high output alternators for a variety of different cars including the Monte. Do a search for "High Output Alternators" and you should have no problem finding one.
Old Dec 4, 2006 | 04:27 AM
mickey's Avatar
Photobucket
kool thanks , just trying to figure this out rught now.
after jumping it off it says it is charging according to the guage. '
so off to ge tthe bat. load tested to see if i have a bad cell. this is all i need it took them 3 months to get it here the last time
Old Dec 5, 2006 | 01:25 AM
Yeah let me know what the deal is with that yellow top...I was thinking of getting one...especially since I am getting the Monte a new 1700 watt amp for christmas...she deserves it.
Old Dec 5, 2006 | 04:02 AM
mickey's Avatar
Photobucket
personally i like the bat. and even when jumping it off it is not useing much to do it.
i have seen others out there also that i would look in to also.
stinger is one of the ones i would look in to if i had to do it again.
but honestly im happy with the performance i have had with this one.i just think i have a bad cell in it. something that could happen at any time with any bat.
i will let you know how they deal with the warrenty on it as the bat was bought in
feb 06 and here we are in Dec 06.
Old Dec 5, 2006 | 04:04 AM
mickey's Avatar
Photobucket
Old Dec 7, 2006 | 04:58 PM
matts's Avatar
easiest way to tell if a altenator is charging: with the car running take a screwdriver (or anything steel) and stick it to the back of the altenator. if you feel a magnetic pull then the alt is charging. from there you can still check the alt. with a multimeter to see what kind of voltage it's putting out. if all is good on that end shut the car off and leave it setting for a little bit (20 min or so) and put the multimeter on it and see what the voltage is. shouldn't be less than about 12.5 volts. if both of those check out then put the battery on a load tester. if both of those are good and you're still losing power, you've got something drawing power when it shouldn't be....lol, good luck finding that. i'd start with anything aftermarket you've added and go from there.
hope that helped a little
