alarm in 1988
Old Apr 4, 2010 | 08:05 PM
tony1379's Avatar
Default alarm in 1988
ok here is the problem i bought a car alarm installed everything works fine. It has 2 relays to operate the power door locks which i hook up and they lock and unlock with alarm. But when i try to use the switch inside the car on the door panel to lock or unlock it blows the fuse. I disconect the alarm lock wires and the door panel works fine dosent blow the fuse. any ideas what could be wrong.
Old Apr 4, 2010 | 08:11 PM
mak330's Avatar
thats wierd, ive never used the lock/unlock rocker on my car.
it unlocks by itself in gear, and unlock in park. i just use the fob for everything else.
and you bought the alarm in 1988 or your car is an 88'???
cause if you bought the alarm in 88 id say you got your moneys worth out of it.
Old Apr 4, 2010 | 08:12 PM
mak330's Avatar
did you just get this insatalled or has it been on there for a while???
id say its in the wiring, either way
Old Apr 4, 2010 | 09:46 PM
tony1379's Avatar
the car is a 88 alarm i just picked up used dont even know what kind it is. I have hooked everything up and all works except the door panel switch .I will be rechecking everything tomm. is there anyway to check if one of the relays is bad
Old Apr 4, 2010 | 10:13 PM
mak330's Avatar
im not sure, i think something may be connected wrong. but maybe the switch is just sending too high of amps to your fuse, and blowing it.
Old Apr 13, 2010 | 09:12 PM
tony1379's Avatar
finaaly got it working turned out it was a bad relay changed it now works perfect
jessentexas
Oct 4, 2006 08:40 PM
97silverls
Sep 5, 2006 09:41 AM
metal4ever
Jul 12, 2006 08:51 PM
ngc414
May 10, 2006 10:34 AM
metal4ever
Apr 25, 2005 09:45 AM
