00-05 how to install subs and an amp to your factory head unit
Old 02-29-2012 | 09:53 PM
Originally Posted by MONTE2000SS
i am doing this tomorrow can someone tell me what the two brown wires are for on this line connector cause the instruction say nothing about it at all.....also can i hook up my remote wire to my ignition fuse on drivers side like it is in my 1992 chevy 4x4 .......
what connector?
  #42
Old 02-29-2012 | 10:02 PM
MONTE2000SS's Avatar
loc or line convertor
  #43
Old 02-29-2012 | 10:03 PM
what exactly are you doing?
Trying to run subs without an aftermarket deck?
  #44
Old 02-29-2012 | 10:05 PM
you got it
same deck with subs
  #45
Old 02-29-2012 | 10:06 PM
wher do i put my picture to show up next to my name also
  #46
Old 02-29-2012 | 10:07 PM
you got it
same deck with subs
On the line-out converters not all wires are used, which line-out converter are you using?
You should be able to use that fuse for the remote wire, assuming that fuse loses power after the vehicle is powered down, I'm not sure how this works for a 92 Chevy
  #47
Old 02-29-2012 | 10:09 PM
at the top of the forum: Quick Links -> Edit Options -> Edit Avatar (on left side)
  #48
Old 02-29-2012 | 10:14 PM
no its going in my 2000 ss monte but thanks ill put up something if everything works out aok!!!!!thanks again
  #49
Old 02-29-2012 | 10:19 PM
wanted to see if it worked lol
  #50
Old 02-29-2012 | 10:20 PM
i am using a fierce FILC20V2 for line
