Welding Help???
Old Jul 9, 2007 | 11:46 PM
rcohen's Avatar
Default Welding Help???
Hey guys, instead of bringing my car to a shop to have the mufflers welded in, I was thinking of doing it myself. I have em clamped right now, but there are clear minor leaks. I have a full exhaust and there are several spots other than the mufflers that need to be welded. Anyone reccomend a cheap welder? What type of welder do I need? How much would bringing it to a shop cost vs buying welder (i have a mask and gloves already).
Thanks
Old Jul 20, 2007 | 06:36 AM
ExplosiveSoundz's Avatar
Default RE: Welding Help???
to be honest with you, any good welder that is worth your money will cost between 150-300. and that is the lower grades. It might be alot cheaper for you to pay the 50-70 bucks and have ur local guy just weld them in real quick.
Old Jul 20, 2007 | 06:44 AM
scc24540's Avatar
yeah local fellers charge usually 25 per muffler to weld in place. as far as buying a welder unless you plan to use it alot theres no sense in putting all the money neded into a good enough welder to do the job right
Old Jul 20, 2007 | 07:08 AM
wiz kidd's Avatar
unless your going to get into welding i would take it to an exhaust shop, less of a headache
Old Jul 20, 2007 | 07:17 AM
One other thing to consider, most shops have a hydraulic lift that brings it up to welding height (5-6'). If you try to weld just under the car with a few little jacks, those pipes will get super heated, and there is a chance for 2nd degree burns, easily. My friend that owns a meineke had an employee have to go to the hospital because he didnt raise the jack up enough for adequate ventilation and cooling.
Just a little safety tip. I personally would save urself the aggrevation and pay the dude to do it for you.
2000_BLACK_SS
Mar 27, 2014 05:27 PM
BeachBumMike
Mar 9, 2008 05:37 PM
oldude
Mar 29, 2007 10:45 PM
cj702
Aug 20, 2006 03:20 AM
