Stock Intake vs. CAI
Old 11-24-2010 | 06:58 PM
Crusader SS's Avatar
Default Stock Intake vs. CAI
Good evening all... Quick question about intakes... Will a CAI unit perform $300.00 better than our 6th generation stock intakes with a K&N filter installed?... The reason I ask is that although a CAI unit looks fantastic, is it worth the extra money and will you get an exceptional gain in HP over the stock unit with a K&N?... Also, are our stock units not already a cold air intake?... Just wondering if the money could be used on other mods if the big gains aren't there... Thanks,
Old 11-24-2010 | 07:03 PM
yutzybrian's Avatar
Not worth it unless you need it or just really want the louder sound. I'd spend the money on other mods and use a homemade FWI
Old 11-24-2010 | 07:23 PM
Another reason I ask is that after closer inpection, our stock intakes overall surface size (utilizing a K&N filter) is not any smaller than the surface area of a cone... Also, the length and angle of the connecting tube is short & gently bent... The cold air is collected behind the headlight with a fair sized entrance point... I've also noticed a reasonable increase in performance and sound level with utilizing the K&N... Am I missing something here?... Thanks,
Old 11-24-2010 | 08:14 PM
If you are looking at the K&N FIPK, that isn't a CAI kit. That's really just a hot air kit. I have it myself and I hate it. If you want to look for a good kit, go to zzperformance.com and look for the wizaired kit.
They do work pretty good because they let more air in than the stock system, and it will be louder, but you can just make your own very easily, just make sure it doesn't allow any of the hot air from the engine to the cone.
Old 11-24-2010 | 08:43 PM
Thanks for the info... I guess I'm just trying to justify the $200.00-$300.00 price tag of a true CAI unit against the actual performance gain...
Old 11-24-2010 | 08:57 PM
They are nice to have, they CAN help with MPGs (not much) and they will make your engine sound a lot meaner.
It was the first thing I did to my car, and it is fun to have.
If you think the price is too steep, then you'll probably be disappointed. A ZZP downpipe would be a better way to spend that money.
Old 11-25-2010 | 04:21 AM
monte07's Avatar
it gives a better look and has a better beng in the cold air kit from zzp insted of a ribed intake bend that is on the stock air box.also if you already have it and get the down pipe and other mods it will show it is worth it. remember the better it lets in air and release it the better it will run and the better mpg it will have in the long run
Old 11-25-2010 | 04:13 PM
Took your advise and had a downpipe installed today... WOW!!!... Had I known what the gain in hp and beautiful low tone rumble sound levels would be I would have done it years ago... Thanks a million... I will be installing the CAI unit next Spring, as soon as we get through this North Eastern Winter... Would highly recommend this mod to all!!!... ...
Old 11-25-2010 | 06:43 PM
yutzybrian's Avatar
Wow where did ya get a downpipe that quick? lol
Old 11-25-2010 | 06:49 PM
At our local Performance shop, they deal with quite a few Monte's and custom make exaust systems & CAI units on premises... Cheers,
Quick Reply: Stock Intake vs. CAI
