similar?
Old May 14, 2011 | 10:58 PM
bama_z34's Avatar
Default similar?
are there any similarities between the 5th gen monte carlo exhaust routing and grand prix and newer monte exhaust routing?
Old May 14, 2011 | 11:05 PM
I don't believe they are the same. Your Monte is considered a 1.5 Generation W-Body and we are a 2 Gen
Old May 14, 2011 | 11:18 PM
bama_z34's Avatar
darn. you gotta admit they look afully similar from the bottom
Old May 15, 2011 | 08:52 AM
zipper's Avatar
Back in the day I tried to install a 2nd gen W-body d/p and it wasn't even close to fitting properly sadly. The d/p has a different bolt pattern that doesn't fit our 5th gen exhaust, and the d/p doesn't clear the underbody either. You could use a plasma cutter and cut the underbody to make the d/p fit, just like we have to do to get headers to fit on L36 Z34's. Other then the d/p, I'm not sure how the rest of the exhaust system would work.
God_Bot
FWD Tech Guides '95-'07
Mar 6, 2013 12:42 AM
Montelicious
Jul 6, 2010 02:44 PM
jaws2008
Mar 15, 2010 06:43 PM
srbecker58
Jun 23, 2009 01:26 AM
Cowboy6622
Dec 3, 2007 01:02 PM
