Saturday morning modding
Old Jan 17, 2014 | 10:47 PM
xxtheshockerxx's Avatar
RED DEVIL
Originally Posted by Crusader SS
That's funny...... Is he missing a gasket or is it misalgned?
it isn't aligned properly. Everything is there just something isnt lining up right
Old Jan 17, 2014 | 10:52 PM
Crusader SS's Avatar
Originally Posted by Slugger088
Nice buddy. No issues, install it whenever. Some people have had a slight gap between the box and front frame on the engine, including myself.
I was told by CAI to just make slight adjustments to the box but its been very difficult to make flush with the frame. This issue had No effect on the performance however.
Good luck
Maybe a make shift gasket... My Wizaired CAI came with a wider front gasket and when mounted is not 100% true to the front lip angle, however, the gasket more than compensates for it... The box also has wider gaskets on the sides which also seal the engine compartment at that angle... Hope this helps...
DaNfRoMSt.PaUl's Avatar
Good luck
Seems to be a common issue. I can assure you through much frustration that this is the only way it will sit in there. Im planning on getting some foam to fit on the front of the box to close the gap. Since its in the front away from the motor I doubt it would have any real affect but I would like it to look like its flush.
Old Jan 17, 2014 | 10:55 PM
RED DEVIL
that's a good idea. Mine sits pretty flush but after some hard driving it shifts a little on the left side...less than a quarter inch gap from having a throttle body spacer jammed in there that little thing makes it such a pain to line everything up and throws the whole air intake off a hair.
Old Jan 17, 2014 | 10:56 PM
Be sure to check the sides of the box also, don't want any hot air bleeding into there...
Old Jan 17, 2014 | 10:58 PM
Could one of you guys post a picture of what your CAI looks like?
Old Jan 17, 2014 | 11:01 PM
Here's mine... It's a different brand, but the concept is exactly the same...
Old Jan 17, 2014 | 11:05 PM
I see that gasket along the front. That looks perfect. I should be able to come up with something like that. Is it rubber? The cover fits tight and I cant see how any air would get in that way.
Old Jan 17, 2014 | 11:10 PM
It's a harder rubber, if I was to do it, I would use a softer rubber and replace as needed...
Old Jan 17, 2014 | 11:15 PM
I think im going to try to find a somewhat dense foam to cut in to fit. Shouldn't be to tough. Thanks for the help.
