Oxygen sensor help
Old Oct 19, 2016 | 09:55 AM
dan1313's Avatar
Default Oxygen sensor help
Hi all,
I recently saw the p0132 code on my aero force gauge pop up and replaced my upstream O2 sensor in my 04 s/c dale Jr. For the first week, everything was fine and nothing popped up. For some reason that code is showing up again now and it continues to show. Anyone have any recommendations on what I can do to fix this? I can tell that my sensor is working by reading it on my gauge. Any help would be great, thanks!
Old Oct 19, 2016 | 10:51 AM
Check the wiring for issues if you believe that it is not the oxygen sensor itself.
What brand did you use?
Also, I believe this code can pop up if the car is running excessively rich. Do you have a wideband installed as well?
Old Oct 19, 2016 | 11:31 AM
dan1313's Avatar
I bought a denso brand sensor. Okay, when Zzp tuned it they mentioned something about tuning it a little richer so that could make sense. No I do not have a wideband yet, still trying to get one. I'll check the wiring first and go from there. Thanks for the help
Old Oct 19, 2016 | 02:04 PM
It is safe to tune the car richer to be safe, I doubt they would tune it that rich that it throws that code.
I believe you can unplug the MAF and see if it doesn't trip to help rule out that problem, but I don't know what tables they have altered in the tune
