No P0420 code after running tank of E85?
About a week ago, I got the infamous P0420 code and have been meaning to change the cat, but haven't gotten the chance the past few days. Regardless, I decided to fill the tank up with E85 yesterday (regular unleaded here is around $3.65/Gal whereas E85 is $3.03) and after roughly 20 min of driving, my P0420 code went away and the feeling of backpressure that was there (preventing me from speeding lol) is now gone.
Question is: does E85 burn that differently??? I mean, it burns at a higher temp because of the ethanol.. but other than that? I just found it interesting that it burns differently enough that it can pass through the cat with ease, where regular gasoline just builds up pressure.. |
Ethanol is a clean fuel. Whenever you burn ethanol in your engine, you're also cleaning everything that the ethanol goes through. If your O2 sensor was dirty, it COULD have cleaned it (although I would be a little surprised by that).
I highly recommend running ethanol in vehicles as long as your PCM is ready for it. It's a great high octane fuel. |
Sorry- really off topics here:
(Post 343250)
Indiana I assume? Are you going to Purdue? MET grad '08 here- woot! |
Originally Posted by abro22
(Post 343131)
Originally Posted by 06-montelt2
(Post 343436)
Ive been running E85 lately, actually every fill up for the past 2 months... Im not quite sure if i can see a difference in performance, i mean i havnt tested the gains in any way. I actually did switch to E85 in attempt to cure a problem that i thought could be my cat, but it did not work/help. Im just curies too what should be expected from E85? is it going to help our cars live a little longer or something lol?
Originally Posted by zipper
(Post 343222)
I highly recommend running ethanol in vehicles as long as your PCM is ready for it. It's a great high octane fuel. Since it's clean burning though, it doesn't leave as much carbon in the engine so obviously the engine stays cleaner and supposedly has a longer life span. |
I'm a little car dumb but have a comment/question about this. Is E85 ok to put in my car? 03' monte ss.... stock
ains3614, no. Your car is not "flex-fuel".
thanks
You can make a 3800 capable of running E85 though. It would take larger injectors, a flex fuel fuel filter (I believe from a flex fuel 2004 Chevy Tahoe would work), and a tune. Then you would be all set.
| All times are GMT -5. The time now is 12:28 AM. |
