new cat
Old Sep 1, 2006 | 11:19 AM
01pacecar's Avatar
Default new cat
Well I just got my Monte back from the dealer. My gas mileage has been down by about 2mpg the last couple months but I attributed it to hot weather and running the a/c all the time. Then I started seeing a decrease in power to the point it wouldn't pull even a small hill without downshifting. Took it in and the cat was plugged. Thankfully it fell under the "recall/warranty extension" The old girl flies once again, I didn't realize how much power it had lost because it was kind of gradual until it plugged up bad enough.
Old Sep 1, 2006 | 11:49 AM
montejass's Avatar
Default RE: new cat
How many miles did you have on it??
Old Sep 1, 2006 | 01:27 PM
01pacecar's Avatar
Default RE: new cat
I have 87,900 miles on it. I think it's been slowly going bad for about 3,000 miles. I'm glad they extended the coverage from 5yr/80k to 10yr/150k. While it was in they said my ISS should be replaced, but for $25 parts and $140 labor I'll try it myself.
Old Sep 1, 2006 | 03:04 PM
Bigg J's Avatar
Default RE: new cat
Wow...that's pretty good extended warranty.
Old Sep 1, 2006 | 04:40 PM
01pacecar's Avatar
Default RE: new cat
The warranty is only on the cat and installation and only if you car is in a certain year and vin range.
Old Sep 1, 2006 | 04:48 PM
montejass's Avatar
Default RE: new cat
Did you notice more heat comming from under the car and/or center console? I've noticed a slight heat reduction since I replaced my DP...
If you do end up replacing your ISS please take some pics note your process. Mine is acting up again and I really don't want to take it back to the dealer.
Old Sep 1, 2006 | 11:08 PM
z34phoenix's Avatar
Default RE: new cat
what is a ISS? now you got me wondering... i have 160K on my 96 Z34 power and never seemed to be where i thought it should be from what i heard the stock performance times like 1/4 mile and 0-60 is there any other simptoms that could clue me in if this is the cause? i have a plan in the works to basicly replace the exhaust from the manifolds back, but it would be nice to findout if i should put a rush on the plans if it is a clogged cat.
Old Sep 2, 2006 | 12:15 AM
montejass's Avatar
Default RE: new cat
ISS= Intermediate Steering Shaft.
Old Sep 2, 2006 | 12:52 PM
01pacecar's Avatar
Default RE: new cat
The only thing other than lower gas mileage was the temp gauge ran one mark higher than I remember. No heat thru the console,etc.
I will take pics when I do the ISS. Hopefully I can find time in the next few weeks. It's been acting up for about 40k and seems to be getting worse.
Old Sep 2, 2006 | 01:07 PM
montejass's Avatar
Default RE: new cat
I had my ISS replaced (so they say) under warranty around 30K, 26K later it's right back where it was...
Pictures would be nice just to get an idea what/where this part is.
03SSLE
Jun 22, 2011 06:43 PM
kicker
Apr 2, 2011 09:41 AM
05montess
Feb 21, 2011 05:08 PM
PUNK LIFE
Jun 27, 2010 02:47 PM
MonteDriver
Aug 8, 2009 05:20 PM
