My new CAI
Old Apr 7, 2010 | 05:16 PM
Default My new CAI
just got done putting it together and installing right now, what do you think?? keep in mind the MAF is going between the two red couplers.
Old Apr 7, 2010 | 06:00 PM
Looks like you did a really good job of keeping the bends as gradual as possible- I think it will end up looking pretty good under there!
I do have a question though- why'd you go with different color couplers for the MAF and TB (red and black)?
Old Apr 7, 2010 | 06:05 PM
i knew that was comming. cause i am really anxious to get it on there and all they had was 2 reds and one black. but i think it might look okay cause if you look at the coupler that holds the filter on it black so idk we'll see how it looks. anyway if i dont like it i can exchange it when they get the red ones in.
Old Apr 7, 2010 | 06:06 PM
wtf am i thinking?? you wont even see the one on the filter?? GD meds!! (that doesnt stand for good either) LOL
Old Apr 8, 2010 | 08:18 AM
Looks good, but I think the filter is a little on the small side.
Old Apr 8, 2010 | 10:21 AM
monte07's Avatar
my question is are you routing it under the headlight. if so can you take picks arfer you get it on. second is the cia a biuld your own type? if so what is it?
Old Apr 8, 2010 | 12:06 PM
yeah it going behind the headlight, ill most definaatly take pics for all you. its an airraid, i just bought a bunch of pieces from some place out here and im gonna return teh parts i dont use. i really like those chrome couplers, can you belive those are silicone. the filter is getting changed soon its just for working on it for now. but i got a really huge problem that someone could hopfully help me out with here, i had it all hooked up today and when i went to start the car, it wouldnt> well, it started for about a split second. i mean everythings hooked up right. of course i hooked the battery up, is there something im missing that i have to do?? i hooked up the stock intake after i couldnt get it to run and there was no problem at all ,started write up. please hellp me out here.
Old Apr 8, 2010 | 01:30 PM
Doesn't make sense- only two plugs in the intake should be the IAT and MAF- as long as you plugged those both back in you should be fine. You sure you had the MAF in and the right way?
Old Apr 8, 2010 | 01:39 PM
yeah everything was correct, the only thing i can think of is that the battery wasnt tight enough. i mean it was on the terminal pretty good but there was still room to tighten it, do you think that couldve been it??
Old Apr 8, 2010 | 02:14 PM
Be careful not to over-tighten your battery terminals.
