Engine Build: Just a question
Old Jan 1, 2023 | 10:34 AM
willienmelissac's Avatar
Default Just a question
What does it mean when a 2000 Monte Carlo engine light flashes
Old Jan 1, 2023 | 11:11 AM
Misfires that can damage the engine.
Old Jan 1, 2023 | 11:40 AM
Agreed - it means park the car until you can fix the issue.
Old Jan 6, 2023 | 12:01 PM
antrmo's Avatar
Is it running rough?
starting and cranking longer than usual?
coolant low?
as said above misfire,, question is why?
Old May 29, 2023 | 07:50 AM
monte07's Avatar
My question is this when was the last time the plug and wirhave been changed? I know the talor type of wires are a good replacement i use them with ngk iridiom spark plug. Second look into getting it scanned. The cam position sensor might be bad or the crank one. After you do the plugs and wires. Get it scanned one of or both of the sensors might be going bad. So do the basic first to know the base line of qhat it not needs. After everything has been done you might know a little more on where you stand. The talor wires i run are a better ohm wires. Hope this helps
Old May 29, 2023 | 07:54 AM
Dont think they ever came back..
Harleymarine
May 4, 2022 05:53 PM
taz7nads
Jul 25, 2012 07:53 PM
red04montels
Mar 25, 2010 04:02 PM
06LT3
Jun 12, 2007 04:56 AM
TGAbreu
Dec 9, 2006 10:31 PM
