Engine Build: Just a question
My question is this when was the last time the plug and wirhave been changed? I know the talor type of wires are a good replacement i use them with ngk iridiom spark plug. Second look into getting it scanned. The cam position sensor might be bad or the crank one. After you do the plugs and wires. Get it scanned one of or both of the sensors might be going bad. So do the basic first to know the base line of qhat it not needs. After everything has been done you might know a little more on where you stand. The talor wires i run are a better ohm wires. Hope this helps
Dont think they ever came back..
