Intake Decision Decisions...
Old Apr 24, 2010 | 05:52 PM
sinceire's Avatar
Default Intake Decision Decisions...
Ive been wanting an intake system for my 6 gen SS (00) NA but it has a SERIES II in it if that helps. 1. First what is the best cold air or hot air? Next please recommend some that youve seen I dont care if its new or used.
( PS also I've assumed this was the cheapest & most basic of mods to start with)
Thanks if advance.
Old Apr 24, 2010 | 07:34 PM
Cold air = more dense = more power, you want a cold air intake- either buy a CAI box (like the Wizair, ZZP, etc)- or build your own FWI which is cheaper (just buy a cone filter, install it in your fender well, and run flexible tubing to connect it back to the engine).
Old Apr 24, 2010 | 07:47 PM
sinceire's Avatar
Ok Ive heard of the ZZP and the Wizair, now building mines is going to be difficult, I know it needs to go in a box right? I think ill just buy one lol.
Old Apr 25, 2010 | 08:40 AM
Hey, if you want, you can check out my pics and see what i did. You have a different engine, but you could still do the same set up.
Old Apr 25, 2010 | 09:16 AM
A FWI is not difficult, and no- the filter does not need to be in a box- a cone filter can sit wherever. All you do, like I said before, is remove the stock airbox, get some flexible tubing, run that from the throttle body into the fender- mount your cone filter on the end of that- in the fender. There is no box needed, because the filter will be surrounded on all sides with cold air- unlike in the engine bay.
I've just usually made my own or bought used (like the K&N for my GXP)- because I can't stand paying $300 for an intake setup.
Old Apr 25, 2010 | 06:10 PM
sinceire's Avatar
Ok thanks, Ill probally end up building my own. Your right thats steep for somthing you can do yourself lol.
Old Apr 25, 2010 | 06:28 PM
04 dale jr supercharged's Avatar
i got one off ebay cheap iam going to make it custom i need to make a box for it i will post some pics up as soon as i get it done tomorrow i will put more pics up but ya go on ebay i paid 45 for it with filter but u can go get some more tubing a make it how u want it its better then the K&n 200 for that and its plastic and it dont loook good IAM ALL ABOUT MAKING IT HOW I LIKE IT
Old Apr 25, 2010 | 06:31 PM
ya thats a good idea but the only problem with that is u dont want the air filter getting wet so if u do put it in your fender make a splash grad or somthing i no u can get one water proff but hey i just like over think stuff good luck when your done let me see it
Old Apr 25, 2010 | 06:41 PM
Jomao_o's Avatar
Will doing this setup you mention give you the same HP gains as the Wiz or ZZ CAI's? thanks.
Old Apr 25, 2010 | 06:59 PM
yeah, i got that ebay intake and added onto it. you can see what i did in my pics if you want. keep in mind, the elbow that came with the ebay intake, i have that inside of the rubber elbow that comes off the T-body(you know, the stock elbow inbetween the tbody and the maf sensor. take a look, i saw a pretty good gain, and i made my engine sound bad ***.
