Help needed!
Good Luck `Jose on finding your `Hiss...
Please post more details, and what it sounds like @ idle or under acceleration...What area is the sound coming from ?
Let us know the AutoZone results...`Ok
Did you check if a kitty is under you Monte ?
LOL KidSpace!
I have this one nutty coworker who can tell you anything and everything about any make and any model like it was written down in front of him, I'll check with him today and see if he has any further insightful wisdom I can pass down to you...
Is your hvac(heat/a/c) stuff turned off? when you hear it, i had notice in our new car (intrigue) it lets a slight hiss out while nothing is on
Yeah man it's one of two things: a vacuum leak, or, least likely but worst possible scenario, a crack in your exhaust manifold.
Try running your engine and spraying the vacuum lines with carb cleaner and if it chokes up then you found it.
i don't sugest that sounds like a nice little engine fire waiting to happen
Carb cleaner has a flash point of about 120* F
let alone the risk you run with the splater getting on your paint and eating throught it
here's the MSDS on Carb Cleaner
http://http://www.crossoil.com/lib/d...or_Cleaner.pdf
