gutted out intake
Old Apr 26, 2006 | 12:22 AM
big green dog's Avatar
Monte Of The Month - July 2005
Default gutted out intake
i finally finish gutting out my stock air box i like the noise and think i can feel a little more power
Old Apr 26, 2006 | 08:43 AM
montejass's Avatar
Default RE: gutted out intake
Cool, what did you use to gut it? What kind of filter did you use?
Old Apr 26, 2006 | 10:54 AM
Hi Alex,
Please post pic's if possible and post what was gutted and how you did it.
Are you using stock air filter ? Let the forum know if it helped MPG or not...
Thanks. `d-no in `Space, Fl
Old Apr 26, 2006 | 02:55 PM
montejass's Avatar
When I did mine I used a RotoZip, basically you just start cutting plastic till you get a big opening to your filter area. Right now the box is split into two sections, the space between those two leading to your filter is about the size of a tennis ball, with this modification you can open it up to roughly a 5X5 area. I went back with a K&N as well.
Old Apr 26, 2006 | 02:59 PM
04MonteLS's Avatar
why do you gut the intake?
Old Apr 26, 2006 | 03:01 PM
montejass's Avatar
I did mine for more airflow. It actually sounds better too.
The factory box is so damn restrictive and it was the cheap and dirty thing to do at the time...
Old Apr 26, 2006 | 03:07 PM
04MonteLS's Avatar
ORIGINAL: montejass
ah, ok.
Are you able to do this mod while using an aftermarket drop-in filter? I have a True Flow filter and would be interested in doing this if possible.
Old Apr 26, 2006 | 03:35 PM
montejass's Avatar
If the filter fits the factory Monte airbox it will work. Just make sure you don't cut up the lip holding the filter in place. You'll see what I am talking about when you pull your box apart.
Old Apr 26, 2006 | 07:21 PM
yeah i had it a little gutted already ill get some pics but i can hear it and it feels like i got alitte more power but that may just be in my head it has definitly picked up since i bought it and all ive done is cut out k&n filter gutted box and reprogrammed my chip. one of these days im gonna take my sub and amp out just to see how fast it is without all the extra weight
Old May 3, 2006 | 05:22 AM
BlueEssEss's Avatar
I've also gutted my airbox, and have felt a slight improvement in acceleration, but mostly I can hear a definitely increase in the growl from the engine, so much that it almost sounds like a V8. That plus my exhaust create a pretty nice sound, and when I get my ubend delete done on (most likely) Friday I'll have even that much more power and sound.
