Exhaust Question
Old May 24, 2010 | 12:18 PM
kmt's Avatar
kmt
Default Exhaust Question
Currently have 2 Magnaflow mufflers installed on my car with the rest of the exhaust stock and its real quiet. What can I do to make it louder? Been reading and everyone seems to agree that getting rid of the stock resonator will result in sounding bad but would a glasspack inplace of the resonator be the same?
Thanks
Old May 24, 2010 | 12:26 PM
Hi `KMT,
If you have already checked out our Exhaust section, then
check back to see what our member's with your
Generation Monte post of your question.
Until then you might want to check out
YouTube for sound/vid clips.
Most poster's states what they have done to their Monte's.
Click the below link & explore
Good Luck
http://www.youtube.com/results?searc...haust+%3F&aq=f
Old May 24, 2010 | 12:29 PM
0:28Added to
queue
dale jr. monte carlo with a twist
2004 Monte Carlo Dale Jr. Edition. Lambo's, Neons, 2500 watt Infinit Sound System, Flowmaster Exhaust, K and N Cold Air Intake, Supercharged ...
by fambamuce | 9 months ago | 1,209 views
Old May 24, 2010 | 01:29 PM
saigashooter's Avatar
I removed the cat from mine, and that woke it up some. If you wanted you could do a high-flow cat from ZZP that would remove the restriction, make it a little louder and add a little power.
Old May 31, 2010 | 07:32 PM
kmt's Avatar
kmt
3" Downpipe with high flow cat is in the plans. Thanks
Old May 31, 2010 | 09:01 PM
It depends on what you wanna hear coming from your car. If you get rid of the res, it wont make it sound "bad". Its just that it gives it a bit more of a raspy sound and some people dont like that. It really dosent do that much any way, its more of what it makes it sound like inside the car. The whole point of the res is to keep the in cab drone quieter.
The downpipe is what really makes it louder and for sure the three inch is gonna do so. I think anybody who is wanting to do an exhaust job, is gonna be happy with it as long as it dont have a ricer sound.
Old Jun 2, 2010 | 12:22 PM
drewskie043's Avatar
replace the stock resonator with a shorter one. i think the stock ones are around 18", so get a 14" magnaflow resonator. that will get you more sound. othwerwise, just replace with a straight pipe.
Old Jun 2, 2010 | 12:25 PM
Cam your engine.
Old Jun 2, 2010 | 01:49 PM
MAMONTE's Avatar
This is EXACTLY what I did...I replaced the stock resonator with a 14" Magnaflow. Made it a little louder, but mainly made it just have an overall better tone.
Old Jun 2, 2010 | 10:33 PM
kmt's Avatar
kmt
Awsome, would you happen to have a video clip?
