exhaust help plz
Old Mar 16, 2011 | 03:16 AM
zachary's Avatar
Default exhaust help plz
i broke the two exhaust bolts on my 3.8 and all i can find at the junkyard is a 3.1 will the bolts line up with mine?
Old Mar 16, 2011 | 05:43 AM
Have you checked your local parts stores or Muffler Shops since you only need 2 bolts...I don't think the 3.1L will line up.
Old Mar 16, 2011 | 07:49 AM
What bolts did you break?
Old Mar 16, 2011 | 07:52 AM
TheMonteMan's Avatar
if you just need bolts i dont see why you cant go to the hardware store and get some.
Old Mar 16, 2011 | 02:28 PM
zachary's Avatar
The ones in the back that bolts the two exhaust together
Old Mar 16, 2011 | 03:35 PM
So you broke the 2 bolts at the Cat and Resonator?
Go to any hardware store and get M10x1.50 bolts
Old Mar 16, 2011 | 04:56 PM
zachary's Avatar
The bolts on the cat are fine I broke the one you get to from the top on the sided of the motor in the back.
Old Mar 16, 2011 | 05:05 PM
I think the exhaust manifold bolts are the same size, although I'm not 100%
Old Mar 16, 2011 | 05:39 PM
zachary's Avatar
I just look at the exhaust the bolts broke and are stuck in the holes how can I get them out or can I use an exhaust off a 3.1 cuz I can't find a 3.8
http://www.facebook.com/photo.php?fb...3451317&ref=nf
Old Mar 16, 2011 | 08:52 PM
No, the rear manifolds off of a 3100 will not be the same as that.
Just drill and tap those bolts out, it's not hard.
http://www.jeepfan.com/tech/siezed.htm
