(Post 706246)
Honestly with how loud it's going to be open cutout, the rasp won't matter at all. As mentioned above, the drone / resonance of a cutout under the car is REALLY bad without a turbo. I've got this on both my monte and grand prix and it is fun for a bit, but its not enjoyable long term like a nice normal exhaust is going out the back.
(Post 706246)
Any particular reason you're against just doing a cutout at the back (or even some vacuum actuated mufflers)? Crazy loud exhaust isn't so hard to deal with when it's pointing out the back of the car.
1 Attachment(s)
Originally Posted by Keudn
(Post 706232)
I want loud for the cutout being open I just want to get rid of any 3800 rasp. However perhaps a cherry bomb isn't the best idea.
Keep in mind, the further back (more pipe between engine and cutout) the raspier it gets. You can counter this to an extent with larger diameter pipe but that gets pretty costly.. Having the cutout literally IN the downpipe or immediately after it wont sound all that bad and you may even be able to get away with sticking a smaller diameter "round" muffler/resonator up in there where the res/cat would go.. Thats if you delete the res/cat.. You can also squeeze a couple more inches of room by eliminating the res/cat heatshield.. But then thats gonna add to the drone inside the car.. Heres a picture of when I had stock DP and 2.5 inch exhaust just to give you an idea of what it looks like with the heatshield removed.. I dont know if zippy's pics had that removed but heres mine anyway.. Attachment 35191 EDIT: Just wanna add that it looks like there is WAY more room than there actually is.. |
I think what I am going to do is put a cutout behind the res on the pipe that bends and runs towards the passenger side of the car. There should be enough room there for a small muffler like a cherry bomb extreme, plus it will be pointing out the right side of the car.
https://cimg7.ibsrv.net/gimg/monteca...4eea23ae52.jpg I will probably get the cutout welded in by a shop and then if I decide I want a loud muffler on it to reduce the rasping then I will bolt on one and see how it sounds. |
I have two Flowmaster 40 series on my 3.4, u-bend delete, and am always getting compliment s on how good it sounds! Not going to get the nice V8 sound, but what I have sounds damn nice, and the comments substantiate that!! People think it's cool that I have that sound in a relatively newer car (2003), and they all say they never heard any other Monte sound like it! Most Montes are church-mouse quiet!
I was gonna recommend that.. See how the cutout sounds by itself just whatever you do, dont go getting anything that is supposed to "amplify" the volume or tone.. All that does is make it sound like crap..
Just remember what I said, the longer the piping between the engine and exhaust opening, the raspier it gets.. And it does so pretty quick. Id even suggest first to unhook the res/cat from the DP and see how that sounds just for comparison after you get the work done.. Its too bad youre not doing the welding yourself cause you have a ton more room for experimenting.. One thing to think about here tho, you can get exhaust pipe sleeves and clamps. Honestly theres nothing that makes that route worse than welding.. Itll surely save you some money and you have that "play around" room to see what works and what you like more.. +1 on the side exit idea. Always something I wanted to do with the 6th gens.. |
Originally Posted by Warhorse
(Post 706279)
Always nice to hear someone likes it other than me.. I have the thrush welded mufflers which are almost the same thing.. Cant see them sounding too much different.. |
(Post 706278)
I'm just thinking if that's the case, you could really hurt ground clearance. It's bad enough having a pipe run under the floor pan by itself, but a muffler will make that a couple inches closer to the ground. |
(Post 706285)
If you were to add a cutout there and want to add a muffler later, wouldn't the muffler be mounted completely under flat part of the floor pan?
(Post 706281)
(Post 706287)
Yeah, im not going to get a normal sized muffler like my borlas though. I'm considering a cherry bomb extreme or something like this which won't reduce the ground clearance anymore than the pipe is already
Yeah the cutout will be far enough back to probably make it raspy, and if it is I'll start looking for mufflers to bolt on and test. I wish I could weld them myself but I haven't learned how to weld yet nor do I have a welder :(
(Post 706287)
I was always also very concerned about having someone weld on my car because seriously most of the time they (shops) dont take every possible precaution to eliminate the possibility of damaging something.. Ive seen many that will actually leave a car running if its a quick patch job or something small like that.. |
(Post 706291)
Before youre dead set on having someone weld stuff do a little research on exhaust sleeves and clamps.. I know some people hate even the idea of that kinda setup (i was one) but I ended up doing it that way and ran it like that for about a year with no leaking issue or anything..
