Well then... other option it is ;)
(Post 469350)
im almost positive its clogged because i can barely hear my exhaust anymore :thumbsdown: |
Go for it, if it's not illegal in your area. Just realize when you delete it, your exhaust will smell a little more than usual but that is now normal.
And you'll need the P0420 code deleted from your PCM |
(Post 469360)
And you'll need the P0420 code deleted from your PCM a few minutes ago i was reving up the car, and its making some hissing noise around where the cat is, i reved it to 4k rpms and held it there for about 10 seconds and i see that the CEL starts flashing for a little bit then stops. my temp gauge also went past the 3/4 mark! :eek:. my engine bay has been getting extremely hot to the touch these past few days too, radiator support, braces and engine mounts.... could these be other symptoms of a bad cat? |
Wow your car gets hot... Mine never reaches halfway mark xD But i do have a tune for a 180* tstat. Have you seen your cat glowing red?
Sure does seem like a clogged cat...
Originally Posted by blueSS
(Post 469418)
(Post 469421)
Check out my recent post in this thread Frank: https://montecarloforum.com/forum/pr...-thread-36908/
(Post 469437)
;) I think I'm just going to go with a universal cat welded on, should be cheaper :o Edit: i changed my mind :rotfl: |
I deleted my cat years ago.....
I havent noticed any "change" in the smell of the exhaust....But it sure breathes a whole lot better! ;) |
