Catalytic converter
Hey everybody i got my catalytic converter cut off the other day i also cut off the resonator and ran it back intoback into fake dual exhaust withflow 40 mufflers and of course the check engine light came on the person who did it told me it would happen does anyone know how do turn it off i cant take it to a dealership becouse of no cat
RE: Catalytic converter
You can use an resistor in place to fake the 02 sensors reading.
A resistor won't cut itand neither will an O2 Spoof sensor. On the 04 plus models the O2 sensor not only measures the gas but the heat as well. - Found that out from Zoomer at ZZP.
There are only5 things to do. 1. Purchase a programmer and set code P420 to off so it doesn't trigger the O2 light. 2.Purchase an OBD2 scanner and clear the code every time it comes up. 3. Pull the light in the gauge cluster. 4. Ignore it. 5. Put a piece of black tape over it. I recommend only doing the first one. |
lol at suggestion #5 ...:D
I like that one ... I wanted to remove my cat when i install my magnaflows ... |
