CAI problem
Old Jan 6, 2010 | 08:25 PM
Tdogg527's Avatar
Default CAI problem
Ok i am really just looking for input on this. I got a Cold Air Intake for my birthday for my 06 i had it on there for about a week and the check engine light came on. So i used my dad's SCT tuner for his F-150 and checked the codes because my reader would not check them because its too new. It was the Map sensor code....it would go on and off for a while...Then i had to replace thermostat and the temp sensor so i put back on the facoty air box minus the silencer and the code is gone. Could the CAI cause the computer to throw this code???
Thanks
Trent
Old Jan 6, 2010 | 08:42 PM
Cowboy6622's Avatar
On my '03, there is a plug that goes in just before the throttle body along the air box passage way. If the new CAI doesn't have this plug or the little reciever for it is not right, that could be the problem. I don't know if the '06 has this said plug or not though. I do know on mine that when it is unplugged, the A/C does not work, but I don't remember it throwing the code.
My first thought whne you said this was that the oil from the air filter on that thing had gummed up your Mass Air Flow sensor.. that happens sometimes when people re-oil their K&N.
Old Jan 6, 2010 | 08:45 PM
I think the problem lies in your sig..
CHEAP EBAY CAI
Old Jan 6, 2010 | 08:55 PM
Tdogg527's Avatar
yea could be but its off now i just want to know if it would throw a code
Old Jan 6, 2010 | 09:10 PM
If a connector isn't working properly it can throw a code. But just having a CAI won't throw one.
Old Jan 7, 2010 | 01:01 PM
MAMONTE's Avatar
I have a real CAI on my 06 and NEVER had a problem with it. The Ebay ones are garbage, and not even real CAI's. If you really want a CAI, go to www.coldairinductions.com and order their's. Its more money for sure, but you get what you pay for! I highly recommend this intake for the 06-07 V6's, works great.
Good Luck!
Old Jan 7, 2010 | 01:53 PM
Cowboy6622's Avatar
Years ago, we used to call the crappy ones that weren't insulated and the such "Hot Air Intakes"
Old Jan 7, 2010 | 04:04 PM
yeah ebay parts are junk unless ur buying a good brand & not some unknown brand
Old Feb 10, 2010 | 07:09 PM
Tdogg527's Avatar
ok well i put the factory air system back on it and it was fine for a while...But it came back on and i replaced the Map sensor. After a while it came back on tonight along with the "P0690 ECM/PCM Power Relay Sense Circuit High" code....What does this mean? I think the map sensor just needs the connector cleaned. But what could the other code be?
Thanks
Trent
Old Feb 10, 2010 | 08:12 PM
monte07's Avatar
check the conectors do you have a warrenty still on your monty? if so have them check your car out. also check if a groung that might got loose in that area.
