Buying flow40, confirmation on size and procedure needed
Old Dec 26, 2009 | 03:01 PM
Absolutpolack's Avatar
Default Buying flow40, confirmation on size and procedure needed
So I got $200 in gift certs to Jegs this christmas and am going to get flowmaster 40s for my 2001 MC. I measured it was 2.25" pipes, offset in and centered out (looked like offset in, without lifting the car up). Does this seem correct.
Also, how do the hangers work, im sure they're not standard so will I have to fab some up and weld them on? Also it looks like I have a 8" long pipe converting the 2.25" output from the muffler to the 2.5" for my tips (from PO). Is this a standard part or a jerry rig from the PO putting on tips?
TIA
Old Dec 29, 2009 | 08:32 PM
So after jacking it up and remeasuring/checking the inlet size to the mufflers is 2in not 2.25in. Turns out they don't sell 2" flowmaster 40s. Might have to go with the Delta models.
Old Dec 29, 2009 | 10:21 PM
vita's Avatar
hmmm... are you sure? I KNOW its possible to get 40s put on there. Let me see if I can do some digging and get back to you. When I had my monte (it was an LS) I had dual 40's put on. I think my tubing was 2"... ?
Old Dec 30, 2009 | 11:27 AM
Thanks! Well they may exist but JEGS doesn't sell them. As I have $200 to JEGS thats really the only place I can afford to buy...
Old Dec 30, 2009 | 12:48 PM
MAMONTE's Avatar
A muffler shop could weld in a 2-2.25 inch converter pipe to make it work, just ask around, i'm pretty sure it would not be that big of a deal for a shop to do this.
Old Dec 30, 2009 | 02:14 PM
vita's Avatar
^ bingo. Checked my receipt from my LS and thats what it looks like they did.
Id go check, but the car was sold a while ago.
Old Dec 30, 2009 | 05:42 PM
huh mine is 2.25" & its the stock piping untill nxt month when i either go 2.5" or 2.75" idk which im gonna do, u can always try make the nxt size up fit the car possably
Old Dec 31, 2009 | 06:55 AM
Im gonna order the 2.25 inchers and get a shop to weld them on. Hopefully wont cost me too much.
DaNfRoMSt.PaUl
Jan 8, 2014 10:34 AM
forgotten
Jan 12, 2012 06:32 AM
intimindatorguy
Oct 2, 2010 11:39 PM
Endo
Jan 13, 2009 01:49 PM
