Beginner upgrades for '05 Monte Carlo SS?
I have been doing research on some beginning upgrades to my stock '05 SS and just have a few questions. I read the upgrade plan by bunpin and have decided to get a CAI from cold air inductions, exhaust cutout, and maybe the downpipe.
For the exhaust cutout where is the best spot to put this and what size should I get? I have seen people put them between the cat and o2 sensor. Is this the best spot for them or is there spots that are easier to install them and will work better? For the downpipe the guide says get the ZZP 3" but what will be the difference between the 3" and 2.5"? I'm short on cash so if I don't have to spend more on the 3" I don't want to. Also I have heard if you downpipe you should also get the plog from them as well. Is that mod necessary and what benefits will I get from it because like I said, low on cash lol. |
LoL by the title of your thread I thought you're talking about the actual starter itself.
Originally Posted by Habbibie
(Post 662963)
get the 2.5 down pipe,it will take care of the U bend where the second 02 sensor sits that's the most restrictive part of the exhaust,and while your there id go ahead and spray some PB blaster on the exhaust bolts so they don't become rusted on over time,i got lucky with mine
I have a 2005 Monte carlo SS.
I installed a Stainless Power Log & a ceramic coated crossover pipe from ZZP & a high flow cat & down pipe from summit racing, cold air intake I made with parts. from ebay & auto zone & home depot https://scontent-ord.xx.fbcdn.net/hp...d4&oe=56060DAC |
My exhaust cut out is installed at the bottom of the downpipe. We moved the Hi-flo (Magna-flow) cat towards the rear more, made an extension for the 02 sensor and plugged it in behind the cat.
http://i280.photobucket.com/albums/k...psqma1370j.jpg Look and you can see the small Magnaflow CAT and on the bend past the CAT you can see the 02 sensor installed on the pipe. http://i280.photobucket.com/albums/k...pszied0pf1.jpg |
Originally Posted by ZIPPY02
(Post 663038)
I also installed my cutout where the downpipe bends at the firewall. My cutout faces straight down to the ground. You can install the cutout anywhere after your up stream o2 sensor. The down stream o2 sensor can be turned off with a tune an d the cutout can be in front of it with no issues.
Next I would just buy headers if I were you. Why piece together a plog and down pipe when for not much more you can have headers. I'm assuming your supercharged with being a 05. Once you get a intake and headers, get a step colder plugs and drop the sc pulley size to make more boost for more hp. (This will require a tune as soon as you change this pulley!) |
(Post 663089)
Next I would just buy headers if I were you. Why piece together a plog and down pipe when for not much more you can have headers. I'm assuming your supercharged with being a 05. Once you get a intake and headers, get a step colder plugs and drop the sc pulley size to make more boost for more hp. (This will require a tune as soon as you change this pulley!) Also what headers should I get? |
x2 on just get headers instead of a Plog and downpipe.
