air intake
Old Dec 14, 2008 | 04:44 PM
kingzen34's Avatar
Default air intake
Plain and simple I took out the air filter box in my 01 monte carlo ss, and i put a cold air filter on the end of the hose that connected to the stock air box, and I was curious if this is going to mess up the engine in any way or if its going to give me horse power gain or loss.
Old Dec 14, 2008 | 05:47 PM
inssanity21's Avatar
Default RE: air intake
it seems that with your set up you might be losing power. this is because
1: you still have part of the air box right in front of it keeping cold air from getting to it
2: you also have no heat shield.
warm air= less power
cold air = more power
Old Dec 14, 2008 | 06:35 PM
black04monteSS's Avatar
Tear out the factory part thats left through the core support behind the headlight...there is a freakin huge hole through there out it in there... a heat sheild would also help but i'd say it still has to flow better than stock
Old Dec 14, 2008 | 07:10 PM
RocknSS04's Avatar
DEFINATELY need a heat shield. I'd remove the old air box, also.
Old Dec 14, 2008 | 10:31 PM
kingzen34's Avatar
I was going to remove the other part of the box, but theirs what seems like a computer or some sort of sensor box inside there im not sure if its going to affect it if i take it out and put it out of the box.
Old Dec 15, 2008 | 08:38 AM
Nocturnx's Avatar
That's the PCM. You can buy a PCM tray to mount it to once you've removed the rest of the stock airbox.
Old Dec 15, 2008 | 05:18 PM
Nope, a cold air intake isolates the filter from engine bay heat. What you installed is called a hot air intake.
I would say a loss. My reason behind that is you made your situation worse instead of better.
If you cut that filter so it laid out flat, I bet your actual surface area is similar in size to stock- so your restriction to flow through the filter probably remained the same.
You still left the corrogated intake tubing that causes minor turbulence in the intake. The only part you eliminated was the back part of the airbox that really has no effect on anything.
Then, you opened up the intake to the very hot radiator fan wash, and now you're drawing in air less than a foot from a super hot exhaust crossover (ever touch that thing after you get done driving?). Not to mention, heat rises- so all the hot air from the engine bay is building up around your filter and the underside of the hood when you come to a stop. Before, it took cool air in from behind the headlight- which never really sees any hot air, and almost immediately goes to ambient temperature once you start moving.
Old Dec 16, 2008 | 08:59 PM
Enzo354's Avatar
STILL SLOW
well see how mine works, mines similar but with a chrome tube. The middle of it is i nthe area where the old one was (have yet to cut apart old air box, but I just did it for the sound and looks, although im sure it gives a bit of performance untill it gets very heated up in the engine.
Old Dec 26, 2008 | 11:43 PM
kingzen34's Avatar
i finished making the air intake tube and i took out the old air box out of it check it out, all i need now is a heat shield/ insulation, which i will hopefully get from a hardware store for cheap. take a look
Old Dec 27, 2008 | 07:58 AM
mrl390's Avatar
Looks good.
